PXAMG install - AM/SAT button not working??
I was recently finishing up the install of my PXAMG iPod adapter + HDRT HD Radio tuner into my 2006 IS350 (w/ ML DVD Nav). HD Radio and iPod adapter were working great while I was putting the car interior pieces back together.
However, when I had finished putting everything back in place and was adjusting the location of the PXAMG and HDRT (having to unplug the two DIN connectors and the harness then reconnecting), I noticed that I could no longer access the SAT (thus, the HD and iPod) option when I pushed the "AM/SAT" button.
I tried resetting the PXAMG a few times and trying a different PGHTY1 harness (even trying a second PXAMG I had with me), but I can't get into SAT mode.
Questions:
1. By pushing the AM/SAT button in stock condition, will our radio normally go into the SAT mode, even without an XM/Sirius/PXAMG connected?
2. Has anyone ever experienced a loss of the ability to go into SAT (HD/iPod) mode with their PXAMG?
Thanks!
Questions:
Thanks!
Our AM/SAT button stopped working last month. Neither the AM nor SAT function works. It may have coincided with the battery going dead. Did you ever figure out your problem?
Did you resolve your problem? I have a similar situation with my "SAT" button not working.
I installed a sirius tuner and adapter on my 2007 IS250 and was not receiving any text, only the channel number in satellite mode. I tried removing the connectors to see if they were loose. After I re-installed everything the SAT button doesn't work. Is there a reset for the radio or did I blow something up?
lexi4darin
05-07-07 11:23 PM
IS0LD0UT
03-09-05 09:45 AM
