vsc and check engine light!!!!
Old Sep 2, 2009 | 07:32 PM
hustlerx80's Avatar
hustlerx80
Default vsc and check engine light!!!!
so i decided to change out my hid headlight and also my high beam and drl lights...i change my headlights with a d4s bulb and a 1watt high beam with led drl lights...after i changed it out my check engine with the vsc light came on...does this happen to anyone else ...can someone help me pls.
Old Sep 2, 2009 | 08:01 PM
dubsesd's Avatar
dubsesd
i swapped in some HID's in my IS and the same thing happened. i have a code reader and just cleared the code. it may take 4-6 restarts to get rid of the lights, or you may have to clear the codes
Old Sep 2, 2009 | 08:46 PM
ELL Y's Avatar
ELL Y
Goes away normally. It's probably because you disconnected the air intake box and the sensor that's on it. Give it a few drives and it'll disappear.
Old Sep 2, 2009 | 09:33 PM
Phil888's Avatar
Phil888
You should take it to the dealership and have them safely remove the code for you. Thats the reason why we have warranties.
Old Sep 3, 2009 | 12:12 AM
hustlerx80's Avatar
hustlerx80
well i decided to take one of the bulbs out to check if its bad...and it looked fine...after reinstalling it the light went away but then one of my bulbs kept going out, so i had to turn of my headlights, then turn it back on. but it kept on turning off on me and den it died completely, but the good thing was the check engine and the vsc light went away. so i swap the left bulb to the right bulb and now both bulbs work normally after a quick test drive, but the check engine and vsc came back on...but i guess ill drive it a couple of times like wat all of you said and hopefully it will go away permanently. thanks for all the input u guys rock. ill post up some pics tomorrow, if all goes well lol.
Old Sep 25, 2012 | 06:57 AM
Matap's Avatar
Matap
Old thread, but glad I found this. Thanks for the info
Icy350
Dec 9, 2025 11:11 AM
GBunce
Jan 9, 2024 09:11 AM
Joppa013
Oct 27, 2017 12:44 PM
joetarin
RX - 1st Gen (1999-2003)
Apr 26, 2017 06:34 PM
06pearlex
Apr 2, 2011 12:46 PM
