Redouts
Old Aug 31, 2009 | 10:08 PM
gdcheng's Avatar
gdcheng
Default Redouts
So I got some redouts and put them on my car this afternoon. Not knowing what to expect as far as installation goes, I installed one side which went pretty easily but had one tiny crease. Barely even noticable. Now I knew what to expect for the other side which went on much easier and came out perfect. So of course I want both sides to be perfect now. So the question to you guys is, has anyone tried to take off some redouts? Is it easy and do they come of smoothly with no residue? They are cheap enough to try again and get both side perfect if that is the case.
Old Aug 31, 2009 | 11:54 PM
funnie's Avatar
funnie
where did u get them from ? i tried to stretch out the red outs, but it will only make it worse. If you got them from r-vinyl, i heard people just contact them n tell them that you messed up on the install and they will send you an extra set.
That or just purchase another set, its pretty inexpensive. Good luck n show some pics of your work =)
Old Aug 31, 2009 | 11:55 PM
mo12hammad's Avatar
mo12hammad
buy a new set. if u really care that much about something thats not noticeable
Old Sep 1, 2009 | 12:05 AM
Lazy's Avatar
Lazy
heatgun + goo gone?
Old Sep 1, 2009 | 07:52 AM
gdcheng's Avatar
gdcheng
I am not concerned about getting a new set of redouts, I just don't want to take the ones I have off now and realize that I shouldn't have because the ones that are on are way to difficult to pull off.
Old Sep 1, 2009 | 08:12 AM
SD.IS's Avatar
SD.IS
i got mine from ebay and i took it off like 6 bajillion times trying to install them perfectly haha
Old Sep 1, 2009 | 08:50 AM
joeker's Avatar
joeker
take a dull blade and start peeling it off at the corner. lubricate it with some water/baby shampoo solution and start to peel more and more. see if this does the trick, if not just purchase another set from aero-tect. it's really cheap
Old Sep 1, 2009 | 04:04 PM
i3urton's Avatar
i3urton
depends on how long you had it on for. if longer than 1 hr then leave it on for good u need a new set.
Old Sep 1, 2009 | 07:26 PM
hmsis250's Avatar
hmsis250
use a heat gun to soften up the adhesive and clean residue with prepall or gasoline.
Old Sep 2, 2009 | 11:02 AM
600rr05's Avatar
600rr05
[QUOTE=funnie;4812486]where did u get them from ? i tried to stretch out the red outs, but it will only make it worse. If you got them from r-vinyl, i heard people just contact them n tell them that you messed up on the install and they will send you an extra set.
QUOTE]
+1 you can call them direct they will just make you pay shipping for the new set that is if you bought from them..
Old Sep 2, 2009 | 12:20 PM
dappy's Avatar
dappy
You can certainly remove them, but you'll need a new one afterwards. It's held on with adhesive. You can clean it with simple disposable alcohol wipes.
Old Sep 2, 2009 | 12:22 PM
aliu603's Avatar
aliu603
get some new onessss yeeeee
Kstyle55
Jul 1, 2014 05:36 AM
craigsager
Apr 15, 2014 01:37 PM
TLDriver
CL of Southern California
Jan 18, 2011 08:17 AM
LJGS300
Great Deals
Mar 10, 2008 07:50 PM
|mpulse
Nov 28, 2005 12:23 AM
