HID Problem They keep going off
Old Jul 25, 2009 | 10:00 AM
AKIS350's Avatar
AKIS350
Default HID Problem They keep going off
Not sure if anyone else has this problem..
I replaced the stock HID bulbs with 6k HID and they keep going off when I make a turn. It doesnt happen all the time but it happens alot.
They come back on when i turn the lights off and then on again. Its really sucks. Does anyone have the same problem or no why.
Thanks
Old Jul 25, 2009 | 10:33 AM
four o two's Avatar
four o two
Well, check your connections. Sounds like a ballast or bulb is shifting and coming loose or something. Try and track it down because you're only hurting your equipment by turning it on/off constantly.
Old Jul 25, 2009 | 10:41 AM
joeker's Avatar
joeker
reconnect the harness coming from the power supply to the ballast, see if this helps
Old Jul 25, 2009 | 12:14 PM
Deathrow23's Avatar
Deathrow23
I recently had the same type of issue, but ive never changed the bulb on mine, mine is stock hid, the right headlight would turn off sometimes, happened when i turned right one day at night. but hasnt happened since.
Old Jul 25, 2009 | 01:23 PM
kattanh3's Avatar
kattanh3
i had a similar issue and the dealership fixed it for no cost... so it's gotta be a matter of reconnecting parts properly
Old Jul 25, 2009 | 03:52 PM
AKIS350's Avatar
AKIS350
Thanks ill take a look at it and try to see if there is anything loose
flektone
Mar 4, 2013 09:18 AM
Mesca
Lighting
Jan 16, 2013 10:18 PM
RVCAis250
Dec 4, 2012 09:53 PM
freshrice
Jul 8, 2010 05:02 PM
4double0
Lighting
May 9, 2004 03:11 PM
