Steering wheel removal
Old Jun 30, 2009 | 06:48 AM
badx33's Avatar
badx33
Default Steering wheel removal
I cant find any info on how to remove the steering WHEEL, can anyone help thanks..
Old Jun 30, 2009 | 09:29 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
It's pretty straight forward. Remove the airbag (there are two screws underneath cover panels on the steering wheel's lower side), disconnect the spiral cable, remove the nut holding the wheel on (after marking the position so you can put it back on correctly), then use a steering wheel puller to remove the wheel (unless you want to just gorilla it off.)
Old Jun 30, 2009 | 09:30 AM
ilocke's Avatar
ilocke
lol @ "gorilla it off".
Old Jun 30, 2009 | 12:22 PM
badx33's Avatar
badx33
thanks bro..
Old Nov 9, 2009 | 10:02 PM
Dj_AmtraX's Avatar
Dj_AmtraX
Do you really need a puller? Does it mean I have to take it to a stealership?
Old Nov 10, 2009 | 07:32 AM
javyLSU's Avatar
javyLSU
2IS OG
You can borrow a puller from any Auto Zone for a $20 refundable deposit.
Javier
Old Nov 10, 2009 | 07:41 AM
ESBob72's Avatar
ESBob72
You forgot one VERY important part of the process. Disconnect the negative terminal on your battery and wait about two minutes. Especially when disconnecting or reconnecting airbags.
Old Nov 11, 2009 | 07:58 AM
Dj_AmtraX's Avatar
Dj_AmtraX
Any tips on how to line up the new wheel? I am replacing my stock with IS-F wheel.
Old Nov 11, 2009 | 08:10 AM
javyLSU's Avatar
javyLSU
2IS OG
^Lance answered this above:
... remove the nut holding the wheel on (after marking the position so you can put it back on correctly)...
Javier
Old Nov 11, 2009 | 09:54 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Javier
Not really, he's not reusing the old wheel, he's replacing it with a new wheel.
Lou
Old Nov 11, 2009 | 10:04 AM
javyLSU's Avatar
javyLSU
2IS OG
He can mark the new wheel in the sameplace. The steering wheel has grooves like a gear, so it's not hard to line it up properly.
Javier
Batmobile
Oct 27, 2022 01:57 PM
Hiep25
Jun 3, 2018 02:18 PM
Damage
IS F (2008-2014)
Sep 5, 2010 06:17 AM
VIP_LS
Dec 10, 2008 06:07 AM
Grip
Jun 10, 2008 05:37 PM
