installing wiper blade help???
Old Mar 1, 2007 | 09:21 AM
Bichon's Avatar
Bichon
Originally Posted by neova
I agree. The OEM wiper blades works fine. It's quiet and it does it job nicely.
One danger in changing just the rubber insert, as opposed to the entire blade assembly, is that you need to be careful the rubber insert is attached properly and securely without any loose spots. If there are any loose spots then when the blade changes direction, it will produce a squeaking sound because there is movement between the blade and the rubber insert.
I would just go and buy another OEM blade assembly when it's time.
Huge difference in price. From CL vendor www.lexus-parts.com, the inserts run $14.86 for the pair, the whole blades will set you back $59.91 a pair.
If the inserts are installed properly, which isn't that difficult, they'll work fine.
Old Mar 1, 2007 | 09:56 AM
ES3's Avatar
ES3
Is there really much of a difference between the factory inserts and any aftermarket replacement? Is replacing the blades just as easy with any aftermarket blade?
Old Mar 1, 2007 | 09:59 AM
Technique's Avatar
Technique
CL Folding 500,000
Typically I replace the whole blades (including arms) every other time... So, for example, once a year (15k miles) I replace the blades inserts only, then the next year (30k miles) I replace the whole blade assembly...
I think maybe the blades get slightly bent/deformed after a few years, especially if they get iced over in bad weather, etc... Maybe the heat in the summer also warps them slightly, but I find that after about 2 years, even with brand new inserts, they don't work as well...
Just my experience with replacing wipers...
Old Mar 1, 2007 | 10:00 AM
Technique's Avatar
Technique
CL Folding 500,000
I'd stick with the factory blades and inserts... They work great and are not that expensive...
Old Mar 1, 2007 | 10:07 AM
Bichon's Avatar
Bichon
In my experience, yes. The two times I tried third-party blades from an auto parts store (once Anco and once a triple-edge product), they were so bad that I tossed them in the trash and replaced them with OEM the very first time it rained.
Old Mar 1, 2007 | 11:48 AM
sarge43's Avatar
sarge43
Originally Posted by bagwell
+1
I've had the car alsmot 2 months and haven't used the wipers yet but I might try the PIAA Silicone blades.
Looks like the end result is the same as using Rain-X and regular blades. You get the shielding action of Rain-X. Just use with a good quality blade and you're good to go.
Old Sep 9, 2007 | 06:26 AM
bulwinkl24's Avatar
bulwinkl24
Default wiper blades
has anybody changed the wiper blade inserts on a gen 2 IS yet? if so, how is it done? i tried to get the old insert out by trying to take the blade assembly apart but i didnt want to use to much force in fear of breaking the entire assembly.
Old Sep 9, 2007 | 11:16 AM
ecr527's Avatar
ecr527
I'd like to know as well. I have to change mine out soon too.
Old Sep 23, 2007 | 12:43 AM
ES3's Avatar
ES3
Just noticed my passenger side blade is slightly bent, it's about 2 inches higher on one end than the other, should i try to replace the insert first, or do you think I'll need to replace the whole arm? I am pretty sure it happened in the Lexus car wash... they do a hand wash, but I fear the car was left on and the rain sensing wipers went while they were soaping up the windshield!
Old Sep 23, 2007 | 01:50 AM
MPstyle's Avatar
MPstyle
I have the PIAA Super Sporza with those sweet little "spoilers" they are cool.
Old Sep 23, 2007 | 09:57 AM
Joeb427's Avatar
Joeb427
Bosch Icons on my vehicles.
Old Feb 2, 2008 | 07:56 PM
TLP_IS350's Avatar
TLP_IS350
i have bosch icons and they suck anus! i use PIAAs on my other vehicles and they are terrific! but im not sure if i'll put them on the IS cause i like how the OEM ones are aerodynamic and flow nice with the lines of the IS. (i am a very detailed person) Whereas the PIAA's look like plain wipers and i dont want the PIAA's with the "spoilers" PLUS i think the OEM wipers are one of the best OEM wipers i've ever used.
Old Feb 3, 2008 | 02:43 AM
iialcii's Avatar
iialcii
Rain X works charms. I love it. will replace blades when needed.
Old Nov 2, 2008 | 10:18 PM
aaalead's Avatar
aaalead
How do you remove the wiper assembly on an ES 330. Does the blade assembly need to be stopped in the upright position and then removed?
Old Nov 3, 2008 | 06:41 AM
Jefe's IS's Avatar
Jefe's IS
Check out Consumer Reports. They just did a test on wipers. I think you may be suprised.
