installing wiper blade help???
Old May 6, 2009 | 08:20 PM
  #46
ELL Y's Avatar
ELL Y
Oh man windshield wiper blades are a royal pain to change in general. Also, depending on the brand of windshield wiper you buy, they may use their own proprietary technology (so slightly different procedures). Basically, you'll awnt to pull the wiper blade up (so that they're facing up), then it's usually shoving a big blocky piece out of a u shaped hook. When that u shaped hook is bare, you can insert the new one.
http://www.ehow.com/video_107_replac...eld-wiper.html
Here is a quick helpful video I found.
It's pretty easy if you just examine the structure closely.
Old May 8, 2009 | 07:09 PM
  #47
Evil Teo's Avatar
Evil Teo
make the wipers go up like when u wash the car and windshield. the wiper blade u have there is like a small metal piece that sticks out. if u look closely it looks like it gets hooked on.
look at the one ur takin out. the piece that is attach to the arm u have to press something to make a metal piece pop up and then u unhook it. probably sounds confusin but thats what i did to replace mines.
Old May 8, 2009 | 07:21 PM
  #48
acefalcon2's Avatar
acefalcon2
how to replace the whole wiper.. the blade is the rubber blade rightt?? so how to change the wiper itself?
Old May 8, 2009 | 09:08 PM
  #49
txguy977's Avatar
txguy977
I just get the wiper blade insert from the dealer and have them install for free...
Old May 9, 2009 | 12:33 AM
  #50
love67's Avatar
love67
did he mean he just wants to change the rubber and keep the whole thing??? because we can't buy a whole wiper is like ours that pretty right?
Old May 9, 2009 | 05:42 AM
  #51
T4styPh0's Avatar
T4styPh0
Sounds like I should make another DIY
Old May 7, 2010 | 06:20 AM
  #52
Nicelex13's Avatar
Nicelex13
bump bump bump?
Old May 7, 2010 | 10:09 AM
  #53
dixieman's Avatar
dixieman
Please do one for the OEM rubber inserts!!
Old May 7, 2010 | 10:23 AM
  #54
Nicelex13's Avatar
Nicelex13
thats why i bumped lol
Old Aug 16, 2010 | 06:26 PM
  #55
BADFNZ's Avatar
BADFNZ
What size (width) are the refills? The stupid computer at Advance Auto said the driver side was 7mm and the passenger 6mm. I was 99% sure they weren't different sizes, but I bought both anyways knowing I'd just return the ones I didn't use. Well guess what, neither size works. Both are too thin, so I guess 8mm might be the one?
Old Aug 17, 2010 | 08:32 AM
  #56
dojoman's Avatar
dojoman
It's very easy to replace the refill. The hardest part was taking out the arm, the rest is piece of cake.
Old Jan 7, 2011 | 12:31 PM
  #57
nsxiboi's Avatar
nsxiboi
After reading all 4 pages, I'm still having trouble trying to replace these. Can somebody help? thanks
Old Jan 7, 2011 | 07:12 PM
  #58
sjgIS350's Avatar
sjgIS350
Wow..my post from almost 4 years ago lives
What part do you want to replace? The rubber only...the refill? or the blade? (the rubber and metal frame). I am assuming not the arm..the part that connects the blade to the wiper motor mechanism.
See post 2 from Tammy...pretty much tells you how (look at the pdf too),
Old Jan 7, 2011 | 08:44 PM
  #59
nsxiboi's Avatar
nsxiboi
I'm replacing the rubber only. Yea, I already read the PDF from Tammy. I'm already stuck on the first step, "Remove the wiper from the arm." HOWW???
Old Jan 7, 2011 | 08:55 PM
  #60
sjgIS350's Avatar
sjgIS350
there is a tab you have to pry up..use a small flat blade screwdriver
