touch screen trouble!
Old Apr 20, 2009 | 12:15 AM
whantonsou's Avatar
whantonsou
Default touch screen trouble!
So, Today was a hot day in Los Angeles... which is not a problem... This morning I drive to church, and leave my car out in the hot sun for 12 hours.. Everything in my car works fine..except when i go to touch the navi screen... It doesn't respond. EVERYTHING WORKS (when i hit menu, dest, or audio) but it doesn't respond to my touch....
Does anyone else have this problem....It is really bothering me, because it feels like i lost control over 50% of my car's function...
BTW, I have not done any hacks to it in anyway.
Old Apr 20, 2009 | 01:07 AM
jayz250's Avatar
jayz250
One word: Dealership.
Old Apr 20, 2009 | 06:15 AM
Jefe's IS's Avatar
Jefe's IS
The touch screen works by differentiating the temp of your finger and the screen. Your screen was too warm to detect a touch. I bet it works fine once the interior has cooled.
Old Apr 20, 2009 | 12:00 PM
blk250's Avatar
blk250
Good to know..will not leave the car under the hot sun...
Old Apr 20, 2009 | 12:20 PM
kattanh3's Avatar
kattanh3
you can cool the interior as much as you want and it probably won't work... i had this issue and had to change my screen under warranty good thing they swapped the whole central unit for me so there was no need for them to take off the screen
Old Apr 20, 2009 | 01:50 PM
Bichon's Avatar
Bichon
I've never had this problem, even after parking in the sun on a 107 degree day. Sounds like something is wrong with the OP's screen.
Old Apr 20, 2009 | 02:43 PM
2SwiFt29's Avatar
2SwiFt29
Mine didn't work also, but it wasn't because of the heat.. ended up going to the dealership to have it replaced under warranty.. only thing that's different is that I don't know if this happened before, but when i go to the audio stations or the temperature setting, it would change back to the map screen after a while without me pressing the Map button..
this doesn't have to do with the navi, but I also replaced the cluster because the needle on the mph side was a little dim compared to the others.. got it replaced and noticed they gave me a 07-08 cluster because i have the fog light indicator now..
Old Apr 20, 2009 | 02:48 PM
whantonsou's Avatar
whantonsou
So...I don't have a warranty... and they are saying it will be around 2500$ to replace the unit. Is there any after market units i can put in its place?
Old Apr 20, 2009 | 03:09 PM
Feirax's Avatar
Feirax
The nav has an option to auto switch back to the map screen, I'm not sure off the top of my head but I believe you hit the info->settings and it'll give you a screen with the option.
This might sound silly but have you tried cleaning the screen thoroughly? Especially at the edges. My iPhone for example, if the screen gets too dirty the phone sees it as me holding my finger on it and seemingly stops responding. A good cleaning and it's as good as new. Good luck.
Old Apr 20, 2009 | 03:39 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
HAHA.... not! The screen is pressure sensitive.
Old Apr 20, 2009 | 05:47 PM
whantonsou's Avatar
whantonsou
...I wish it was a simple cleaning problem.... but no matter what i do, It won't respond to my touch......OH well....2400$ to fix the stupid problem...at least my maps will be updated..
Old Apr 21, 2009 | 10:18 AM
kattanh3's Avatar
kattanh3
try to get your hands on a good screen from a salvaged car or something, swapping screens will probably save the day
Old Apr 21, 2009 | 10:41 AM
Emarati_K's Avatar
Emarati_K
I had this problem before, I couldn't find a solution. I guess it's because of the hot weather. In my country temperature reaches 45C+ in summer which effected on my navi last summer and I took it to the dealer and there was no solution other than changing it.
Old Apr 21, 2009 | 01:43 PM
Bichon's Avatar
Bichon
How far out of warranty are you? If it was me, I'd be asking the dealer and Lexus for "good will" coverage for the repair, or at least part of it. It's worth a try...
Old May 13, 2009 | 07:01 AM
AaronFL's Avatar
AaronFL
Crap, I just had the same thing happen to me and I am just over 50k mile warranty. So the only solution is to drop $2500? seems a bit excessive.
