Spacer install
Old Apr 1, 2009 | 12:57 AM
Stevoe88's Avatar
Stevoe88
Default Spacer install
So, I am told that installing spacers isn't as easy as it looks ... Can anyone clarify exactly what needs to be done when installing one? I'm getting the H&R 15mm spacers for the rear. Local shop is charging me 100 dollars to install them and I was wondering if its easy enough to just do it myself ...
Old Apr 1, 2009 | 01:30 AM
JDKane527's Avatar
JDKane527
CL Folding 25,000
Easy one is Ichiba V2 spacers. With V1 and most H&R Spacers, you need to remove the original wheel studs. Somewhat of a harder/more permanent fixture. I'd leave it to the shop to do for $100.
Old Apr 1, 2009 | 07:02 AM
bullet1's Avatar
bullet1
To do it yourself you would need a wheel stud tool. So if you don't have one of those, I would have a shop do it. Or get the Ichiba V2 spacers which is what I have and they went on in about a 1/2 hour for all 4. Cake install.
Old Apr 1, 2009 | 11:16 AM
Stevoe88's Avatar
Stevoe88
Would the Ichiba V2's have problems with vibrations and getting loose faster than the other versions since its just direct bolt on?
Old Apr 1, 2009 | 01:01 PM
JDKane527's Avatar
JDKane527
CL Folding 25,000
It shouldn't if you torque them properly.
Old Apr 1, 2009 | 01:58 PM
bullet1's Avatar
bullet1
I haven't had mine for as long as some folks here, but I have no problems with vibrations at all.
Old Apr 1, 2009 | 03:49 PM
jns350's Avatar
jns350
Great thing about Ichiba's..is that they are hub centric and will keep the wheel centered. This design helps to minimize the chance of vibrations
Get the V2's so you can easily remove the spacers in the future and they are a direct bolt on application so you don't need to spend $ at the shop to swap your studs. Are you doing this on a stock wheel setup??
Old Apr 1, 2009 | 09:25 PM
blk250's Avatar
blk250
should check with Mister T.. he had Ichiba's b4...and 20mm rear and 15mm front...
Old Apr 1, 2009 | 09:58 PM
ankurman20's Avatar
ankurman20
CL Folding 25,000
I have Ichiba V2 spacers and they were really easy to install... all you need is the right socket and a torque wrench to make sure you dont over tightened it...
Old Apr 2, 2009 | 09:32 AM
scalum1994's Avatar
scalum1994
do the Ichiba v2 spacers come in 5mm and 10mm. i've only seen them offered in 15 and 20mm. thanks.
Old Apr 2, 2009 | 10:18 AM
JDKane527's Avatar
JDKane527
CL Folding 25,000
They don't get down to 5 or 10 mm.
Old Apr 2, 2009 | 11:17 AM
fasteddy91's Avatar
fasteddy91
The million dollar question is how is the reliabilty of having spacers long term? I have heard from people having them for a year with no problems, but i'm looking for those that have had spacers for 5 plus years with no bearing issues.
Old Apr 3, 2009 | 02:39 PM
iLL TL's Avatar
iLL TL
^ x2.
how reliable are they
Old Apr 3, 2009 | 09:47 PM
bullet1's Avatar
bullet1
Good luck finding an answer to this.
https://www.clublexus.com/forums/is-...ty-issues.html
Such a fun group.
Old Apr 3, 2009 | 10:26 PM
Hayk's Avatar
Hayk
Just when I plan to add spacers, I find out that it can seriously mess up my car... Similar thing happened with my plans to use lowering springs, apparently the headlights get out of whack.
zibby07
Sep 1, 2011 02:57 PM
iCON
Jul 22, 2011 08:32 AM
designo
Sep 21, 2010 05:25 PM
Baby ///M3
Oct 17, 2008 05:27 AM
PecosBill
Sep 4, 2008 11:41 AM
