Gfx Kit Need Help
Old Sep 24, 2008 | 02:37 PM
LeXusIS714's Avatar
LeXusIS714
Installing is super easy for side skirt and okay for the rear and front. You don't have to cut or drill anything on the front lip or rear. Just follow the DYI in the forum and take your time. I installed front, side, and rear in 2 hours without any help or special tools. GL and PM me if you need help.
Old Sep 26, 2008 | 08:57 AM
scruffydog's Avatar
scruffydog
Check out these Instructions before you try installing them....it may seem very intimidating, but it's not that bad once you actually do them yourself. I think the rocker panels were the easiest since I didn't have to drill holes. (Which btw, I really recommend you do drill holes because it does a much cleaner job holding the skirts together with the stock bumpers)
http://sewellpartsonline.com/import/pdf/IS_complete.pdf
I hope you appreciate this, because it took me forever to search for these instructions when I had my kit. Usually this instruction will come with your kit, but for some reason I didn't get it when I got my Rear Ground Effect Kit.
Old Sep 26, 2008 | 09:22 AM
scruffydog's Avatar
scruffydog
Default DIY - Front Ground Effect Kit Install Instructions
Thanks to Sewell and Lexus, the credit goes to them...
Old Sep 26, 2008 | 09:23 AM
scruffydog's Avatar
scruffydog
Default DIY - Side Ground Effect Kit Install Instructions
Old Sep 26, 2008 | 09:26 AM
scruffydog's Avatar
scruffydog
Default DIY - Rear Ground Effect Kit Install Instructions
Old Sep 26, 2008 | 09:39 AM
AsianGirl007's Avatar
AsianGirl007
Lexus Diva
Thanks for posting the instructions.
For those of you who missed out on Sewell's GB, they're doing another one late next month and they will have all the colors that sold out because they're ordering more right now.
Please check the vendor forums so you don't miss it again.
chaos6458
Sep 24, 2010 04:43 PM
AMSPHAN
Mar 16, 2010 05:23 PM
TommyT
Sep 9, 2008 06:11 PM
chris07is
CL of Southern California
Aug 20, 2008 11:40 AM
RVN
Aug 8, 2008 03:41 PM
