Fuel Injector Cleaning
Old Aug 31, 2008 | 08:33 PM
DeviousOne's Avatar
DeviousOne
Default Fuel Injector Cleaning
I just got my car serviced for its 30k check up and was told two things:
1: I need to get Fuel Injectors cleaned because of carbon build up and
2: Need to change rear dif fluid cause it is "dirty"
Anyone else have to do this at or around 30 k?
Old Sep 1, 2008 | 01:39 PM
DrGP's Avatar
DrGP
Throw in a bottle of Chevron "Techron" fuel injector cleaner. For the next 2 gasoline "fill ups", make sure you use a "top tier gasoline" . That should solve your fuel system issue. I hope that you have been using premium gas, since non premiums blends don't alway contain the same anounts of detergents as the premium grades. Also I do not believe that the top tier brands contain ethanol either. http://www.toptiergas.com/
Old Sep 1, 2008 | 01:49 PM
iSuxeL's Avatar
iSuxeL
I actually had them clean my carbon build up it was around $230 or something, but the rear diff fluid I did myself, I used Royal Purple 75w-90 about 2qts. Just fill it till it pours out
Old Sep 1, 2008 | 04:26 PM
15951's Avatar
15951
Like many other petroleum companies, Chevron blends in up to 10% ethanol in its fuel: http://www.chevron.com/deliveringene...fuels/ethanol/
Also, read here if you're interested some interesting writing on additives and detergents, and the real difference between regular and premium fuel: http://www.straightdope.com/columns/...nd-regular-gas
Finally, just a couple of things to think about with Top Tier gasoline (largely taken from a USA Today article about same (http://www.usatoday.com/money/indust...gas-usat_N.htm ):
1. Certification as a "top tier" provider requires little more than a letter to the certifying "organization" (and I'm using that lightly) that the gasoline seller will meet Top Tier standards. There is no regular testing, or even initial testing to certify standards are met.
2. QuikTrip is first on the "top tier" retailer list, and just happens to be the company that came up with the idea and certifies all others. See post #7 here: http://www.northamericanmotoring.com...d.php?t=127972. Draw your own conclusions.
I fully bought into the Top Tier thing for awhile, until I did a little reading and realized it's 95% marketing and 5% quality.
Old Sep 1, 2008 | 06:02 PM
DeviousOne's Avatar
DeviousOne
I primarily use Shell 91. That's the highest we have around here. I think they quoted me around $180 bucks to clean injectors and change rear dif fluid
Old Sep 1, 2008 | 06:05 PM
Koz's Avatar
Koz
This is supposed to be the most effective cleaner on the market today (new and improved). The guys on bobistheoilguy are raving about it.
http://www.amsoil.com/storefront/api.aspx
Koz
Shawnmack
Jan 28, 2021 08:23 AM
bryanc182
Jun 30, 2010 05:06 AM
juguryan
Dec 26, 2006 06:40 PM
kreativ
Maintenance
21
Jul 28, 2002 02:06 AM
jcboiz
Mar 5, 2002 08:55 AM
