Zenon Depot 6000K HID Problem
Old Aug 9, 2008 | 03:54 AM
Vaughn's Avatar
Vaughn
Default Zenon Depot 6000K HID Problem
Having issue with drivers side HID. Bulb fires when car is started, stays on for approx 2 minutes then shuts off. Only happens with drivers side. Is it a bulb issue or ballast issue?
Old Aug 9, 2008 | 04:07 AM
l3lkis250's Avatar
l3lkis250
try swithcing the bulb from ur passenger side and see if it still happens? you'll be able to pin point it from there
Old Aug 9, 2008 | 06:12 AM
devanaire0's Avatar
devanaire0
I had the same issue. I switched the bulbs and had less problems with the driver's side going out. But now I notice that the driver's side still goes out every so often, but nearly as much as before.
This is becoming a trend with the driver's side bulb going out, then being able to be turned back on by turning it on and off. I am starting to firmly believe that Xenon's bulbs are not the issue here. Maybe the driver's side ballast can't maintain the voltage for the higher watt/kelvin (whatever) bulbs. Maybe it is a case where we need to install abetter ballast than the stock ones....maybe then can I get the blueish tint I want from my 8000k bulbs...?
Old Aug 9, 2008 | 06:18 AM
passnu2's Avatar
passnu2
First of all its Xenon Depot
and I don't think its them or the quality of the bulbs. This is too common of a problem with members on here and the drivers side. So there must be a current issue or something that is different on the Drives side of the car to be causing so many issues....The question is what and how to find out?!?!?
Old Aug 9, 2008 | 12:35 PM
w1ck3d64's Avatar
w1ck3d64
yeah a lot of times a batch of HID bulbs are a hit or miss lol so it COULD be the bulbs
like a previous member said...switch the bulbs if the bulb in question goes off on the passenger side...then time to swap those bulbs =)
Old Aug 9, 2008 | 07:47 PM
TLP_IS350's Avatar
TLP_IS350
check to see if your ground is nicely fastened. i forget which side it was but one side shut off on me before and when i turned the lights off and turned it back on it worked fine. Tightened my grounds and nothing has happened since then. my xendon depot 6500K has woked awesome since the day i got it
Old Aug 9, 2008 | 08:40 PM
blklexo818's Avatar
blklexo818
i was having the same problem but i had xenons from xenonking.com and they just replaced both bulbs and gave me a brand new set....its the bulb not the ground or anything, its going bad or its already bad
Old Aug 9, 2008 | 08:50 PM
devanaire0's Avatar
devanaire0
Hmmm. Is it pretty apparent where to tighten the ground? Once again, I have no clue how I would do that.
Old Aug 9, 2008 | 09:35 PM
LILDANTE79's Avatar
LILDANTE79
i had the same problem but it was not my bulbs.. the passenger ballast was not grounding right so i ended up adding an extra ground wire from the ballast to the body.. its worked fine since..
Old Aug 9, 2008 | 10:41 PM
305is350's Avatar
305is350
I'm having the same problem, with the 6000K bulbs from Zenon Depot, I swaped the bulbs this afternoon from side to side to see what happens, but I'm pretty sure is the bulb.
Old Aug 9, 2008 | 10:50 PM
meefer's Avatar
meefer
mine's on my passenger side actually.......intermittent problem. hate to ask a forum vendor for a replacement - it'd ruin the color match =(
Old Aug 9, 2008 | 10:57 PM
kuuqi's Avatar
kuuqi
if it's the same vendor it shouldn't be a problem on color matching unless your bulbs are old and used frequently that it colorshifts. as for HID's not firing up correctly: it's a problem on MANY cars but i've seen this happen on a toyota camry, toyota avalon and lexus IS. see a trend?
it's probably more to do with the way toyota/lexus set up their electrical system that it causes a problem on one side. of course no one has pinpointed this exact problem yet so like others said, switch bulbs and try that. then move on to check other problems. worse comes to worse you can request for a replacement bulb.
Old Aug 10, 2008 | 03:57 PM
nabbun's Avatar
nabbun
my xenon depot kit (9006 Fog Light Kit) came with loose pins in the connectors.
they weren't working when i test fired them and I located the 3 problem pins. The color was supposed to be 3000k Yellow but they came out green.
Going to replace those bulbs with another companies bulbs.
I was kinda disappointed in this kit's quality.
Old Aug 11, 2008 | 11:12 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Hi Guys,
I am sorry to hear that some of you are having a problem. As always, If there is a problem please contact me directly and I will take care of the problem for you to the best of my ability. While I enjoy surfing the forum and responding to threads my PM and email always take priority. Again, we stand behind our product and it would be my pleasure to assist you in any way that I can. Unfortunately, if you do not contact me directly I cannot gaurantee you that I will see the post on the board.
Steve
Old Aug 14, 2008 | 03:40 AM
Vaughn's Avatar
Vaughn
Removed the drivers side bulb, re-installed. Appeared to be a loose connection. Working O.K.now.
