help! problems after putting in HID fogs!!
Old Aug 3, 2008 | 05:39 PM
w1ck3d64's Avatar
w1ck3d64
Default nvm...resolved...thanks!
hi all,
i just put in a 9006 conversion kit and also put in 65W DRLs from MTEC in...
now all the lights are fine... 3 of the windows do not work (but the driver's side works)...i can't even roll them down individually...and the master control on the driver's side doesnt work either for the windows...
any ideas? i don't think i did anything other than do the conversion and DRLs...but i did reconnect and connect the battery a couple of times to check if things were working...did i blow a fuse or something? :S
EDIT: the washers work now... but the windows still don't work...i searched CL and people have said that a master reset will do it...which meant going to each window individually and doing it that way...but i can't even roll them down individually...no blinking lights either...i'm sooo confused
all help is appreciated =)
Old Aug 3, 2008 | 06:08 PM
Brian231's Avatar
Brian231
You need to manually re-set the windows by the master switch one by one. Simply roll down and up all the way each window. The headlamp washers, I have no idea.
Old Aug 3, 2008 | 06:21 PM
w1ck3d64's Avatar
w1ck3d64
the problem is..i can't even roll them down individually :S...i just noticed that the lights for the switches arent on...like during night time...that little green light for the switch...i noticed that for the driver's side too...but the driver's window switch light is on...
EDIT: the washers work now... but the windows still don't work...i search and people have said that a master reset will do it...which meant going to each window individually and doing it that way...but i can't even roll them down individually...no blinking lights either...i'm sooo confused
Old Aug 3, 2008 | 07:41 PM
l3lkis250's Avatar
l3lkis250
when you tried rolling each one manually from "each door", did you make sure the button that allows only the driver to control the windows wasn't on?
Old Aug 3, 2008 | 08:23 PM
w1ck3d64's Avatar
w1ck3d64
yeah i did.....it's kinda weird...i think i'm gonna disconnect my battery again and see if i get the blinking lights so i can reset it =(
Old Aug 3, 2008 | 09:15 PM
w1ck3d64's Avatar
w1ck3d64
ok i redid the battery and it let me reset it now lol....weird -_-
ninja729
Apr 21, 2012 12:27 PM
coleco
May 25, 2011 10:50 AM
sokeen
Dec 27, 2007 03:44 PM
gundaman
Aug 18, 2005 10:07 PM
strat1
GX - 1st Gen (2003-2009)
May 7, 2004 03:11 PM
