TOM'S Linear Throttle System "L.T.S."
Old Jul 26, 2008 | 02:41 PM
xravexboix's Avatar
xravexboix
Default TOM'S Linear Throttle System "L.T.S."
With all the Toyota family going Drive-by-wire (electronic accelerator pedal and throttle body, no more mechanical linkage) many have complained the driving experience is less personal now. We all notice the slight hesitation if you have to floor the pedal.
TOM'S introduced the LTS system. It basically helps correct the throttle input to the throttle body to give a more realistic feel. It's a simple plug and play install and increases the throttle response when engaged. It can also be turned off (auto-off on vehicle start, adjusted via EDFC-like controller) when you don't feel it's needed.
I've tried it in an IS250 and IS350. On the 350, it was quite amazing.
Old Jul 26, 2008 | 02:46 PM
TinCan's Avatar
TinCan
How many dollars?
Old Jul 26, 2008 | 02:49 PM
Mister T's Avatar
Mister T
Carson started carrying this a lil while back.
Amazing you say?
I'd like to find out for myself.
Old Jul 26, 2008 | 03:11 PM
ba-b4's Avatar
ba-b4
how does it differ from driving around in PWR mode? That mode is already kind of agressive.
Old Jul 26, 2008 | 03:31 PM
xravexboix's Avatar
xravexboix
I think the listed price was around $550. or so.
It's hard to describe it exactly, but it's only meant to be used during sporty driving. The ECO mode levels out the response so it feels more natural. I prefered the Sport 1 mode best for normal driving.
Sport 2 and 3 are reducing the overall throttle pedal distance required to arrive at WOT, so it's more for convenience when on the track.
Power mode is similar to the ECO/SP1 mode, but still tons more responsive. It manipulates the throttle response so it's great for the track.
I have a GS version at my house at the moment... but I think Flipside is going to borrow it and report =P
The IS version is on the neighbor's IS at the moment.
Old Jul 27, 2008 | 06:04 AM
t0e's Avatar
t0e
This would be good for the track....
I would buy it, But who's going to install it?
Old Jul 27, 2008 | 01:32 PM
Kurtz's Avatar
Kurtz
All this is doing is telling the system you have the pedal down further than you really do.
Can't you get exactly the same effect just pushing the pedal down further, while spending $0?
Old Jul 27, 2008 | 02:40 PM
nsxiboi's Avatar
nsxiboi
I agree with kurtz. Just step on the gas pedal a few more inches and you'll get the same effect.
Old Jul 27, 2008 | 10:54 PM
illmike's Avatar
illmike
Blitz has something similar out for the IS350...theres a video in action at the posted youtube link.
http://www.youtube.com/watch?v=6TpR7l9fO5o
Old Jul 28, 2008 | 06:35 AM
D.Jobin's Avatar
D.Jobin
How difficult is the install?
Old Jul 28, 2008 | 09:05 AM
TinCan's Avatar
TinCan
Looks pretty easy to do...Just a PnP
Old Jul 28, 2008 | 10:06 AM
xravexboix's Avatar
xravexboix
The install is just PnP. The wire harness from the pedal is unplugged. It it then plugged into the LTS piggy back. The other harness on the LTS is plugged into the pedal. Now you route the wiring for the controller to somewhere good (glove box, center console box) and you're set. The only panel you have to remove for a quicky install is the one above the pedals.
When you floor it, there is still a .5 second (give/take) latency in response and the throttle gradually opens to your requested amount. This will actually go WOT like in a vehicle with mechanical linkage between the accelerator and throttle body.
If anyone wants to go to do a few 1/4 mile runs w/ it on/off, let me know. TOM'S didn't provided any hard information on improvements, but that will likely clear it up for the most part.
Old Jul 28, 2008 | 11:18 AM
Kurtz's Avatar
Kurtz
Given all it's doing is lying to the car about how far you pushed the gas pedal, and the pedal would be floored for a 1/4 mile run, it should be impossible for it to change your 1/4 mile time.
Old Jul 28, 2008 | 11:44 AM
TinCan's Avatar
TinCan
So the blitz and tom are the same part and price?
Old Jul 28, 2008 | 11:58 AM
HKS350's Avatar
HKS350
Idk, It might? If this device is able to open the butterfly faster, then the motors responce will be that; faster. If it takes 0.5 sec for the servo motor to go WOT before, and now its truely 1 to 1 ratio then it could be a little faster in the 1/4. You would see your reaction times change, 60ft times change, & that will change the 1/4 mile times. It would truely be all about the timing. You could do the same with the stock setup but would have to compensate for the 0.5 sec delay, or how ever long it is. My major question would be the motors tuning? Is their enough time for the mechanical to respond? I.E.- the vvti, spark timing, skid ecu? What delay is needed for the proper responce from these devices.
