Which Tips?
Old Jul 22, 2008 | 11:48 PM
MotoX's Avatar
MotoX
Originally Posted by Gr8Dane
Does any know the outlet diameter pipe size. All these tips come in different sizes and length.
Do you mean the inner pipe? The OEM pipe are 2". What you need are the in 2.25" so you can put over the OEM pipe. Hope that help.
Old Aug 7, 2008 | 05:12 PM
Chekmi21's Avatar
Chekmi21
What's a safe length to go with?
Old Aug 7, 2008 | 05:19 PM
w1ck3d64's Avatar
w1ck3d64
tip 1! tip too is too thin :P i like the rounded ends :P
Old Aug 7, 2008 | 05:28 PM
likwid8's Avatar
likwid8
I like the first one.
Old Aug 7, 2008 | 06:01 PM
Chekmi21's Avatar
Chekmi21
The Borlas look great too. Is there a picture of anyone with the Magnaflow tips?
Old Aug 7, 2008 | 07:17 PM
Pnuge88's Avatar
Pnuge88
i measured the tips from the GFX rear lip. its 6.25 or 6.50 inches long. didnt really measure it properly. will the 7.5 stick out too muchh?? i want them flush with the rear lipp
Old Aug 8, 2008 | 08:14 AM
Gr8Dane's Avatar
Gr8Dane
The one I'm looking at doing is Rolled-Round-Angle Cut
part #35177, 4" Diameter, 6.25" long, 2.25" inlet.
http://www.magnaflow.com/02product/s...e=main&id=7776
From what I measured on the stock tips (non-GFX) they were 5.5" long. I'm debating on getting the GFX rear from Sewell's promo., then I will dicide what tips to get.
Old Aug 8, 2008 | 03:31 PM
Chekmi21's Avatar
Chekmi21
Wow those are expensive!
Old Aug 9, 2008 | 06:24 AM
Gr8Dane's Avatar
Gr8Dane
Any website that you buy them from run about $60 ea.
Old Aug 9, 2008 | 06:26 AM
passnu2's Avatar
passnu2
I agree thats a lot for tips....I would just pick up a used exhaust and do it right knowing they are that much plus labor if you have to weld them on....
Old Aug 9, 2008 | 11:32 AM
Navigatn's Avatar
Navigatn
hmm i dunno about that. used tanabe or hks will run u about $450 + labor. set of tips, about $120 + labor. pretty big diff to me.
Old Aug 9, 2008 | 12:42 PM
w1ck3d64's Avatar
w1ck3d64
damn that's exp for just tips...i'd save up and just get an axle back...might as well..ur only off a couple hundred
Old Aug 19, 2008 | 01:53 PM
liazon's Avatar
liazon
not sure why one would pay $350 for flowmaster when Borla is $60 per. they are just tips, purely cosmetic and i don't see that much diff. in the appearance of the two.
Old Oct 3, 2008 | 04:02 PM
MY2J's Avatar
MY2J
so are most of these being welded on? or are there others like the GFX that can be screwed on?
Old Oct 8, 2008 | 08:11 AM
liazon's Avatar
liazon
the borlas have a clamp that is tightened down on the pipe (phillips head screw). a spot weld ensures it stays secure and prevents theft. (Midas $20)
can't speak for the other brands
