JDM LED mirror covers installed
Old Jul 29, 2008 | 03:30 PM
  #61
NOVAGFC350's Avatar
NOVAGFC350
Originally Posted by nnh768
novagfc350 i'm in northern va, manassas, where r u? did u do the install yet? i just ordered it today should come in a few weeks. if you do it can u post pics? or if you want we can do the install together.
Great! I'm probably closer to you than you/i would imagine Yeah! I think we should team up for the install...I'm getting it in a couple of weeks...little delay on my part. You will probably get yours before my. I can stop by to help or just watch while you're installing it. Is your car Glacier Frost or Silver? The pic in your sig looks more of a Silver IS though. I saw a 250 GFM in Manassas about 2 weeks ago but the driver was a girl..she has some aftermartket chrome rims on it Having said that, I saw a silver with red-out tail regularly on Rt66 and actually saw it on Rt28 when i'm heading home this afternoon.
Old Jul 29, 2008 | 05:13 PM
  #62
nnh768's Avatar
nnh768
^^^Sounds good! yea my car is GFM, i see alot around here. My car is stock though except for the redout tail lights.
Old Jul 29, 2008 | 06:15 PM
  #63
NOVAGFC350's Avatar
NOVAGFC350
Exellent! PM me when your mirrors get here. I think I'm about 5-15 mins from you
Old Jul 30, 2008 | 05:55 PM
  #64
loroko's Avatar
loroko
Dammmm nice shots i'll to see my ride with those
Attachment 127993
Old Jul 30, 2008 | 05:57 PM
  #65
passnu2's Avatar
passnu2
I will help you out with what it will look like
Old Jul 30, 2008 | 06:45 PM
  #66
loroko's Avatar
loroko
hahahahaha
now i know how i 'll look like
thank you ...
Old Jul 30, 2008 | 08:08 PM
  #67
nnh768's Avatar
nnh768
i can't wait anymore after seeing the pics, i want them now!!!! hopefully the paint will be a good match, but i heard GFM is hard to replicate...
Old Aug 3, 2008 | 11:44 PM
  #68
blk250's Avatar
blk250
I did the installation for my car, and thanks to this thread I was able to use the driver side wires. Follow passnu2, I ground the wire to the frame, there is a ground bolt under neat the carpet(on driver side). Then I connect the driver's side to the light green (medium wire size, once you open you will know,)and the passenger side to a red color (also medium size...)
You need to have a volt meter, or LED to do the probing while turning the signal. In my case, I use the LED connect the neg. to ground and the pos. connect to a needle , then poking the wires..
There are some red, white, green wires always ON, and the LED does not blink. Once you hit the right green wire, the LED will blink.
Here is the pix of the green wire, the red wire should be close to this.
Old Aug 3, 2008 | 11:49 PM
  #69
blk250's Avatar
blk250
open the door lock cover
Old Aug 3, 2008 | 11:53 PM
  #70
blk250's Avatar
blk250
and more pix
Old Aug 3, 2008 | 11:55 PM
  #71
blk250's Avatar
blk250
untie the door 10mm nut, then just pull out the door panel with a little bit of force...
Old Aug 3, 2008 | 11:59 PM
  #72
blk250's Avatar
blk250
I also found that take off the entire mirror then I can run the wire through easier. You will see 2 10mm nuts through this hole
Old Aug 4, 2008 | 12:01 AM
  #73
blk250's Avatar
blk250
and the other 10mm nut through here
Old Aug 4, 2008 | 12:06 AM
  #74
blk250's Avatar
blk250
You can see, after running the signal wire, and I taped the wires back as org. with new electrical tape..
Those two yellow wires are for puddle light..I wil keep that in mind for the LED door handles, just a thought
Old Aug 4, 2008 | 12:16 AM
  #75
ELL Y's Avatar
ELL Y
wow blk250
you are hardcore
great job though it's still out of my level of skill haha
