Windshield AC vent issue
Old May 1, 2008 | 01:05 PM
isman08's Avatar
isman08
Default Windshield AC vent issue
A piece of small, thin plastic (1/4" by 1/3") fell through the AC vent underneath the inside windshield. Tried to retrieve it with no luck. Is it ok? or will it cause any kind of mechanical damage?
Old May 1, 2008 | 02:11 PM
A.C Milan's Avatar
A.C Milan
i don't think so, it's probably alright.
there was a bee once inside the car and i chased it to let it out but it flew inside and i never saw it coming out, and everything is OK.
Old May 1, 2008 | 06:22 PM
Bichon's Avatar
Bichon
You asked the exact same question a couple of days ago: https://www.clublexus.com/forums/sho...d.php?t=352170
Old May 2, 2008 | 07:18 AM
Brian231's Avatar
Brian231
In order to remove it, you will probably have to remove the whole dash. Kicken8 recommend on your original post that you use a powerful vacuum like possibly a shop vac. I have had great luck with similar situations and using the power of suction/vacuum assist. One time, I had helped a buddy remove a wedge bulb dropped in the housing of his headlight assembly. The shop vac worked like a charm rather than remove the whole headlight. Just make sure you have a good seal to create a better vacuum. You may even turn on the defrost vents full blast.
Old May 2, 2008 | 07:23 AM
isman08's Avatar
isman08
Space between the windshield and the vent is too narrow and I don't think any vacuum suction head will fit in there. I'll give it a try though.
Bichon -I posted it couple of days ago, but was moved to a wrong forum. This is not a detailing issue.
Old May 2, 2008 | 07:26 AM
Brian231's Avatar
Brian231
[QUOTE=isman08;3494644]Space between the windshield and the vent is too narrow and I don't think any vacuum suction head will fit in there. I'll give it a try though.QUOTE]
You just have to get creative and possibly use the thinner adapter designed to vacuum in between the seats. I just went outside to see the clearance of the windshield to the dash. Too bad you did not live near me; I would help you get that plastic item out from your vent.
Old May 2, 2008 | 07:32 AM
passnu2's Avatar
passnu2
[QUOTE=Brian231;3494651]
I agree with Brian that this should work. If not then its down in there an probably would never hurt anything.
Luscombe8A
May 12, 2018 12:22 PM
Ckroush
Dec 22, 2009 11:17 AM
Snowman9000
Lighting
Mar 15, 2004 08:15 AM
xx7xx
Feb 3, 2004 08:50 PM
Silver Ghozt
Mar 2, 2002 06:02 PM
