0-60 and 1/4 mile times with AC
anyone notice any performance degradation with the air conditioner on during 0-60 or 1/4 mile times? i have def noticed improved gas mileage by turning the ac off.
anyone have actual track times comparing with and without? i know it is a bit petty, but i am wondering whether the ac is shut off when the engine is close to red line or before that..in the sense that is there some performance loss before WOT.
well... you do know the only way you can help your mpg with the a/c off is with the windows UP, if you have the windows down and drive around... its actually worse mpg. NOT TO MENTION, all the dust that gets inside behind panels when you do modding
Yes. I drove the LFA.
As soon as you put the pedal over probably about 1/2 throttle.. the a/c turns off.. Will you notice increased gas milage with the a/c off? Probably minimal.. the a/c compressor isnt that big of a drag on the engine, you're talking a couple HP at best. People who say their car is faster with the a/c off are imagining things.
Super Moderator
Not true. The IS has a variable displacement compressor, and sheds the parasitic load of the compressor by dynamically reducing its displacement under hard acceleration. See my comments in this thread: https://www.clublexus.com/forums/sho...d.php?t=346437 as well as this web page at Denso: http://www.globaldensoproducts.com/c...ompressor.html
as far as gas mileage, i've probably noticed about 2-3mpg by turning the AC off whenever I run the 'Auto' system (even if it is running heat).
Super Moderator
It was noted in the press kit back when the IS was first released, among other places.
http://lexus.pressroom.com.au/press_...&kitID=76#1367
That's not been my experience. I've seen more like 1 MPG drop in mild conditions.
