Call Waiting?!
Old Apr 14, 2008 | 01:00 PM
ravz's Avatar
ravz
Default Call Waiting?!
Whats the deal with Call waiting on the BT Handsfree? When I am on a call, and another call comes in I hear the beep beep over and over, but I cannot find a way to switch over.. Am i missing something? I can switch over using the handset.. but that defeats the purpose of the handsfree doesnt it?
Old Apr 14, 2008 | 01:02 PM
MLIAISON's Avatar
MLIAISON
hmmmmmmmm.....I dont have the car yet.....but I would assume that you press and hold the BT button on the stearing wheel to transfer the call?...
Someone correct me if im wrong.
Old Apr 14, 2008 | 01:03 PM
tex2670's Avatar
tex2670
Wouln't you just press the hook button, as if you were answering any call?
Old Apr 14, 2008 | 01:14 PM
tfz_hebe89's Avatar
tfz_hebe89
This is a good question. I have never experienced this b4. Someone experienced can chime in and tell us please
ISF_GG's Avatar
ISF_GG
I've experienced the same issue. And of course I haven't read the owners manual about this yet, so I guess it's time to crack that bad boy open and see what it says, unless someone can definitively answer the question here.
Old Apr 14, 2008 | 01:16 PM
ChrISF's Avatar
ChrISF
i have a question regarding bluetooth. if im in the car and someone calls me, does the call automatically forward to the bluetooth technology?
i have a sidekick3 and last time i checked, it does have bluetooth. so i just enable it every time im in the car for this to work?
Old Apr 14, 2008 | 01:19 PM
stvn's Avatar
stvn
once you setup the BT for the first time, the phone will automatically connect to the car everytime you start the car, assuming you leave BT on for your phone.
Old Apr 14, 2008 | 01:30 PM
tex2670's Avatar
tex2670
You can set it up for auto connect, or manual connect (and you can change it in the settings later on, as well). If you only have 1 phone, you probably want auto.
Old Apr 14, 2008 | 04:03 PM
Little E's Avatar
Little E
I just leave the blue tooth connection on (ON mode) on my cell phone, and everytime I fire up my car with my phone in range (in my purse of pocket) it connects automatically (the nav screen will flash the connectivity).
For it to work, you have to punch in a code on the Nav that will find your blue tooth connection on your phone (you only have to do this once). Once your phone is assigned, you should be good to go!
Old Apr 14, 2008 | 04:04 PM
Little E's Avatar
Little E
Yeah, that's exactly what I was thinking.
Old Apr 14, 2008 | 04:30 PM
Axvel's Avatar
Axvel
you just have to answer the other call on the cell phone itself not through the car system. and yes sometimes it messes up but most of the time it works.
Old Apr 14, 2008 | 04:35 PM
Drunkebuda's Avatar
Drunkebuda
u have to press it on ur cell phone or i think isnt there a hold button or is that on my cell phone ill get back to yah tonight when i check it out on the way home from school.
Old Apr 14, 2008 | 04:40 PM
MLIAISON's Avatar
MLIAISON
I work at a Verizon cellphone store, and if you are using a Bluetooth Device and are engaged in a convo....and another calls beeps in...you have to press and hold your BT Headset (in this case the Car)....
So isnt there a BT Handsfree button on the steering wheel? If so, press and hold that button and it will place the first call on hold, while initiating the 2nd call.
Try this. hope it works for u guys
Old Apr 14, 2008 | 07:10 PM
Sexi_Lexi's Avatar
Sexi_Lexi
There is no BT button on the steering wheel. I usually just end up pressing "send" on the phone itself to click over to the incoming call.
Old Apr 14, 2008 | 07:34 PM
passnu2's Avatar
passnu2
I haven't had this happen yet. I would think that you can hit the talk button on the steering wheel and it should work? will have to try it out...
