oil change ? (Merged with previous thread)
Folks, OCI is a balancing act. No engine will run forever. Eventually it will wear to a point where it needs to be rebuilt. OCI is based on service life and repair cost. You'll spend a certain amount of money on maintaining the engine vs. a certain amount of money rebuilding the engine. From a dollars and cents perspective, if your oil retains its ability to perform the basic functions it is there to do, then it is too early to change it. As its ability degrades (and it does from the first mile you put on it) you play a balancing game. How far can I take it without significantly affecting the engine's service life.
If your idea of service life is 100k miles, you could probably get away with oil changes every 15k unless you drive very short distances all the time. If you expect 200k service life, you'll probably want to cut that down to 10k. If you are going for the million mile engine, then you'd better plan on following the manufacturer's recommendations.
You're going to spend a LOT more money for oil with the million mile plan ($6000 @$30 per change - more if you specify synthetic). Keep in mind, very few of us will keep a car past 100k miles. Using a 10k OCI cuts the oil cost in half. Also, if you are like me, your time is worth money. More trips to the shop to get the oil changed is more lost opportunities to make money. My time gets billed at ~$250 an hour, and I waste at least an hour and a half dealing with an oil change done my someone else. Again, another cost/benefit trade off.
Finally, no matter what oil you choose there will be seals and hoses on the engine that will need to be replaced well before the magic million miles, and often even under the best conditions the rings will wear to a point they do not seal well - especially with forced induction - so it's entirely a balancing act.
With all due respect to the guys at BITOG, the truth about industrial engines is they change oil when the accountant says it makes sense. Not when the wear metals "look" bad, but when the cost of continuing to run the oil outweighs the cost of taking the unit off line for rebuilding. I have a friend who has been doing power production with large engines for many years. He laughs at all the arguments about oil people on the Internet have. When you are changing hundreds of gallons of oil on a 1000 hp generator engine, and you know the engine will only last a certain number of hours at a given load before another rebuild, you really need to think about cost/benefit because it directly affects cost/kW-hour. The accounting guys are always looking for a way to reduce that number.
It's not that people intend to keep their cars 150K, 300K, or 1M miles. It's the thought that a engine that can last 300K will be less likely to break down at 50K compared to the engine that will last 150K.
How much less likely, I don't know. But I think that's really the argument being presented by those who recommend more maintenance vs less. So even though Technique will be out of his car by 50K, the last 10K of those miles could be much more troublesome than the same car but better maintained for the long haul?
I don't believe the likelihood of an oil related failure increases much from 0 - 50k pretty much regardless of your maintenance schedule. It's when you get to 62k miles (100k km) that you start seeing serious problems (like ring sealing or valve stem seal failure) because the iron content of the oil makes it abrasive enough to cause highly accelerated wear rates.
There is no need to guess how long you can safely go between changes. Just send samples to have analyzed at different interval, to see exactly what a safe OCI is.
Koz
Most service interval indicator systems are based on the amount of gasoline consumed (as opposed to time or miles). Someone who drives hard/fast will use more gas and therefore the service indicator will come on earlier (but not early enough for your purposes).
I would change the oil every 6 months with your current mileage.
If you search the archives, you'll find a thread where people have posted their used oil analysis reports. UOAs are inexpensive way to confirm that the oil change interval you're using is appropriate for your specific engine and driving conditions.
Well, this is certainly how my Prius works. I haven't had the IS250 long enough to figure out what they put in there but I'm guessing there's a family trend!
