Bing Bing Bing
Old 02-27-08, 02:26 PM
zduchene
zduchene's Avatar
Default Bing Bing Bing
Has anyone been able to disable the constant beeping noise when:
- You turn off the engine
- Open the driver door
Thanks.
Old 02-27-08, 02:27 PM
Brian231
Brian231's Avatar
I can't stand that either. Probably requires removing the analogue guage cluster and disconecting the small chime speaker.
Old 02-27-08, 02:30 PM
zduchene
zduchene's Avatar
I was thinking that also, but sometimes there is just a relay under the dash that can be jumped to do the same thing without taking the car apart. Hopefully the forum will come up with something....
Old 02-27-08, 02:56 PM
sykocus
sykocus's Avatar
Thanks.
yes it's annoying, but it shouldn't happen as long as you turn off the engine before opening the door.
Old 02-27-08, 02:57 PM
t.is350.h
t.is350.h's Avatar
+1...................
Old 02-27-08, 03:49 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Exclamation
Thats right... Turn off engine then open door... NO BEEP...
Now if you have to do it the other way around for some reason..
Take your left index finger a tap/push on the door switch in the door jamb on the b-pillar.. (above Vin plate area)... it stops beeping...
Joe Z
Old 02-27-08, 03:53 PM
iialcii
iialcii's Avatar
Joe Z
+1 likewise. Or just shut the door and reopen. It will stop beeping
Old 02-27-08, 05:22 PM
Shoganai
Shoganai's Avatar
+1 or push the button with your fingers once you open the door before turning off the engine
Old 02-27-08, 06:00 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
It's more of a bing-bing-bing than a beep-beep-beep...
Old 02-27-08, 08:49 PM
t0e
t0e's Avatar
all this binging, beeping--pinging and ponging...
Im so confused
Old 02-27-08, 11:09 PM
shinbrianj
shinbrianj's Avatar
mine sounds like a microwave when food is done
crazy_vag
02-20-21 10:48 AM
kishy
06-19-20 11:09 AM
deltadelta
11-21-11 03:05 PM
jjwwttyy
06-30-11 10:13 PM
Cut-Throat
08-07-07 02:18 PM
Quick Reply: Bing Bing Bing
