Radio settings?
Old Jan 17, 2008 | 11:41 PM
XprincoX's Avatar
XprincoX
Default Radio settings?
What settings do you guys have your stereo's set at?
My dealer programed mine at:
Bass: 4
Mid: 3
Treb: 5
Old Jan 18, 2008 | 12:20 AM
llamaboiz's Avatar
llamaboiz
bass 4
mid 0
treb 5
Old Jan 18, 2008 | 02:32 AM
4U2eNv_8o8's Avatar
4U2eNv_8o8
Bass: 4
Mid: 0
Treb: 3
Old Jan 18, 2008 | 02:52 AM
06-IS250's Avatar
06-IS250
bass 4 eh? I have it at 1..i like to listen to my music loud..usually in the high 40s and low 50s, and if im really excited, 55+. Dont you guys feel like you will blow your sub and speakers?
I have mine set at
bass : 1
Mid : 1
Treb: 3
is blowing a speaker covered by warranty?
Old Jan 18, 2008 | 03:03 AM
Noz's Avatar
Noz
Bass: 0
Mid: 0
Treb: 0
Why mess with something that the recording, mixing, and mastering engineer worked so hard on. I believe that they do the EQing for you to make things sound relevant to eachother... unless someone down the line had bad ears and screwed up.
Old Jan 18, 2008 | 07:38 AM
D.Jobin's Avatar
D.Jobin
Bass: 2
Mid: 1
Treb: 4
I too like to crank it to 55+
Old Jan 18, 2008 | 08:39 AM
Bichon's Avatar
Bichon
Originally Posted by Noz
Bass: 0
Mid: 0
Treb: 0
It's not that simple.
Fletcher-Munson curves show that human hearing frequency response perception at different volume levels is not flat.
Music that is perfectly equalized at loud volumes will sound like it doesn't have enough bass and treble when you turn the volume down to background listening levels.
Also, you are making the assumption that the audio system is properly equalized for a flat frequency response when the tone controls are set at zero. That may or may not be a correct assumption.
Old Jan 18, 2008 | 08:41 AM
Coconut's Avatar
Coconut
bass: 2
mid: 1
treble: 3
Old Jan 18, 2008 | 10:15 AM
slee18's Avatar
slee18
Base: 1
Mid: 3
Treble: 5
Old Jan 18, 2008 | 10:25 AM
llamaboiz's Avatar
llamaboiz
I listen at 45-50 and i'm NOT worried about blowing spkrs, these are STOCK spkrs remember now (non-ml spkrs handle power in the low 20watt range), the sooner they get blown, the sooner i have an excuse to change them Our non-ml sounds are good, im not saying their not BUT when it comes right down to it... its nothing compared to aftermarket. As for ML? $1k more, 1 more spkr and 100watt more power??? Still its nothing compared to aftermarket...
Old Jan 18, 2008 | 10:59 AM
ABC's Avatar
ABC
CL Folding 100,000
Bass: 2
Mid: 1
Treble: 1
Volume usually between 15-30 depending on how fast i'm driving.
I agree with llamaboiz, the stereo in the IS is decent, but nothing to write home about. I'm still debating whether i shoul ddrop 2-3g on a custom setup... we'll see.
Old Jan 18, 2008 | 01:12 PM
Kurtz's Avatar
Kurtz
It's a whole lot better ($940 for 100 more watts) than I could have gotten spending the same $940 to upgrade the factory system- especially with how difficult replacing the Lexus head unit is.
My previous vehicle had a multi-thousand-dollar system in it, all alpine interior stuff, and all JL Audio for the subs... and the ML system sounds about 95% as good as that one for a whole lot less cost.
Old Jan 18, 2008 | 01:29 PM
xerxes717's Avatar
xerxes717
Bass: 4
Mid: -1
Treb: +1
Old Jan 18, 2008 | 01:31 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
Base: 3
Mid: 2
Treble: 5
Old Jan 18, 2008 | 01:34 PM
moses0324's Avatar
moses0324
Im pretty sure even at max power and max volume you will not be able to blow the speakers...Im sure the speakers can handle more watts than the factory amplifier is giving out...Only makes sense
