Power windows?
The auto up and down doesn't work in all of my passenger windows. The only auto up and down that would work is the drive side window. I can't even open/close the windows through the driver side controls and when i look at the window switches, the light just blinks. Finally, i tried to auto open all the windows through my remote and only the driver side window opens and the sunroof and thats it!!! so im curious if there's a loose connector or if anyone else had this problem??? thanks
you need to reset the position of the windows. you have to do it on every door. just roll down the window a bit and roll it up again. after the window have fully close, dont release your finger and wait for a 'tick' sound.. that's it.. it should work..
If not find the TSIB for the power window in this forum. it's out there....
Oh its here https://www.clublexus.com/forums/sho...d.php?t=324787
The fact that the window switch lights are flashing indicates that the battery was disconnected, and the procedure described by ote111 needs to be performed.
samysarena
Mar 27, 2014 10:50 AM
