Right headlight went out!!
Old Nov 4, 2007 | 10:19 PM
2slow's Avatar
2slow
Default Right headlight went out!!
I washed my car today and somehow when i turned on the car after, the headlight was off. I opened it up and i found water inside. I took out the bulb and used a hair dryer to dry it. I know for sure the bulb is not out because i got the headlight to start working but i turned off the lights to go back inside. Then i tried it again and it stopped working. Is it because it's wet so it's not working? Should i wait it out or take it to the dealership? Thanks
-Tim
Old Nov 4, 2007 | 10:50 PM
Joe Z's Avatar
Joe Z
Exclamation
Sounds like your ballast might have gotten wet some how...
How long have you had the aftermarket bulbs in there???
Was the access cover incorrectly insalled??
Old Nov 4, 2007 | 10:54 PM
2slow's Avatar
2slow
Got the bulbs 1 month ago or less. It was covered and
No water was inside the HID compartment. Only on the wires outside. It worked for a while, until i turned off the headlights.
Where is the OEM ballast located?
Old Nov 4, 2007 | 11:07 PM
Joe Z's Avatar
Joe Z
Lightbulb
^ That I am not sure of.. sorry..
Quick question... Besides your aftermarket bulbs... is the rest of your HID unit OEM or aftermarket??
If its OEM and the wiring gets wet, it shouldn't cause the light to short out..
Unless there is something wrong with the wiring... which may have been caused by the aftermarket 8000K HID bulbs you installed....
Old Nov 4, 2007 | 11:51 PM
2slow's Avatar
2slow
Thanks anyways. Only my bulbs are aftermarket. The ballast is OEM. I'll wait it out and see if the water dries.
Old Nov 4, 2007 | 11:58 PM
mctuners's Avatar
mctuners
Try the non-working side bulb on working side headlight to see if it lights up. If it lights up, it's the ballast and if it does not light up, it's the bulb.
Old Nov 5, 2007 | 09:36 PM
2slow's Avatar
2slow
Yeah, I did that last night. Well tonight i even put in the OEM bulbs back and the right side didn't work. Checked the fuse, it was okay. The thing is.. the headlight will turn on once in a while, So the ballast shouldn't be dead. Maybe loose wires? Maybe take it into Lexus for a check.
smt6
IS F (2008-2014)
14
Dec 15, 2016 07:29 AM
waynedog
Oct 16, 2012 07:45 AM
ltzSupra
Aug 12, 2011 09:38 PM
dhauter
Jun 20, 2011 07:26 AM
2slow
Mar 5, 2009 01:58 PM
