Illuminated Scuff Plates
Do you have memory seats? If not you have neither Lux nor Sport pkg.
(main differences between lux and sports, besides the sport suspension part, is Lux has a power rear sunshade, iilluminated scuff and wood while Sport has no sunshade, AL trim and scuff plates, and sport suspension and sport pedals).
It's possible you have just base (maybe premium, which is just wood and the upgrades seats without memory), plus the Nav/18/HID options (all available without any package)
http://www.lexus.com/models/IS/detai...fications.html
Still lists both AL and Illum as "optional" under scuff plates for 08
Illuminated Entry Illuminated entry system with scuff plates
How hard can it be for Lexus to write up a list of std/optional features??
EDIT--OK, I think I get it. White illuminated is std. Blue illuminated or Aluminum (non-illuminated) are optional if you get the Lux, Sport or X-Package.
The -entry- system is illuminated (puddle lamps, floorwell lamps, etc). The scuffplates are only -optionally- illuminated.
As far as I know ONLY lux/X pkg cars get illiuminated plates... ONLY Sport pkg cars get the AL plates. Everyone else gets the base plates.
08s get white only if illuminated. )6-07s get blue only if illuminated.
I haven't seen any 08s that don't fit the above, but then I haven't seen a ton of 08s either.
https://www.clublexus.com/index.php?...485&Itemid=183
The 2008 IS 250 and 350 features a new finish to its standard 17-inch wheels for a sportier appearance. Additional upgrades include backlighting on the outside power mirror control, white illuminated scuff plates and an additional coin holder.
Then the Lexus press release on the '08 models, I would say, was misleading on that point:
Not really... the blue ones are upgraded to white... the only item it calls out as "standard" are the 17" wheels there.
Granted, it's a little confusing in that he coinholder is certainly standard (sadly) on all 08s, but hey, Lexus also told us for several years the stand-alone ML system plays DVDs, and that's a flat out lie.
Well, that part's an opinion thing :P
Most folks seem to think the white look classier... my wife said the blue looked ricey... some folks really like the blue though.
I've got the Aluminum ones on the sport pkg so it's a non-issue... I think I'd need to see both side by side to really make a decision myself... but if I do that I'd probably like one of em enough to spend the $ to swap em, so I'm in no hurry
They are definitely options, but the way Lexus produces and ships to the US, they are forced options. I suppose if you could get one w/o HIDs or with 17"s if you found a stripped-down base model out there, or could find a region of the country that they may produce them that way, and have it shipped to you. Or special order.
