Did I mess up? Eibach pro-kit question
Old Jun 26, 2007 | 07:37 PM
kicks's Avatar
kicks
Question Did I mess up? Eibach pro-kit question
Hey all, finally got around to ordering Eibach springs for my non-sport 350 But should I have ordered the springs made for the 250 to get the beautiful drop everyone else is running? Or did I do the right thing by ordering the 350 springs? I'm so confused... Thanks in advance for any replies!
Old Jun 26, 2007 | 07:51 PM
gsrthomas's Avatar
gsrthomas
Yes you should of gotten the springs for the IS250. It is more and better of a drop then the IS350 IMO.
I'm still debating whether or not to go with LMS or Eibach springs.
Old Jun 26, 2007 | 08:09 PM
kicks's Avatar
kicks
Thanks for the reply gsrthomas... but does anyone know if weight was the reason for the 350 springs being less aggressive than the 250 springs? The people at Eibach must've had a reason behind this.
I also thought I read somewhere on the forum that the specs posted by Eibach were from a 350 with sport package, does that mean I can assume the front is actually a 1.5" drop on a non-sport?
leegina's Avatar
leegina
But is the ride comprimised because of the spring rates are for a 250 and not the heavier 350? I understand it will look better but will it ride mushy or soft with more bounce. I know we are only talking a couple of hundred pounds but just wondering. Thanks
Old Jun 26, 2007 | 08:10 PM
leegina's Avatar
leegina
I do believe on a non sport it does drop a little more than with the sport package drop
Old Jun 26, 2007 | 08:40 PM
gsrthomas's Avatar
gsrthomas
The difference btw the weight of the IS250 and the IS350 is 92 pounds. Going with IS250 springs will not change the way the IS350 drives, if anything it will drive better because of the more aggressive drop. Passenger weighs more than that.
IS350 curb weight: 3527
IS250 curb weight: 3435
Old Jun 26, 2007 | 09:27 PM
IEMaestro's Avatar
IEMaestro
I didn't know you could use the Eibach IS 250 springs on the IS 350!! What is the difference in drop between the two? I installed the IS 350 springs on my car...but I am planning on slapping on some 20's, so it's probably better that I went with the more conservative drop.
Old Jun 26, 2007 | 10:24 PM
knihc2008's Avatar
knihc2008
IS250 has a larger drop than IS350 springs
Old Jun 26, 2007 | 11:29 PM
MoLexus's Avatar
MoLexus
Yea but nothing major. Whats the difference that you guys have seen or better yet post up pictures to compare.
Old Jun 27, 2007 | 05:30 AM
taylorjste's Avatar
taylorjste
i seriously doubt that anyone would be able to tell the difference between the two.. we're talking probably around .25-.33 inch difference if you factor in the tolerance and settling.. therefore, i would much rather have the springs that were designed for your specific model by the manufacurer.. just my opinion
Old Jun 27, 2007 | 06:26 AM
Toptier's Avatar
Toptier
I second that.
Old Jun 28, 2007 | 02:23 AM
kicks's Avatar
kicks
I totally agree... Most of the Eibach drops I've seen on here look more aggressive than the 1"/0.8" Eibach lists it as, so I guess I was just wondering if other members with the 350 were using the 250 springs.
Thanks again to those that have replied!
NitrousNik
Suspension and Brakes
Oct 9, 2011 03:37 PM
mjh09e
Aug 20, 2011 05:45 AM
sincityIS
Apr 4, 2008 12:24 PM
inwood
Jan 25, 2008 07:34 PM
sincityIS
18
Jul 15, 2007 01:37 PM
