1st time at the track
Old May 27, 2007 | 08:16 AM
  #31
caymandive's Avatar
caymandive
11 Second Club
Originally Posted by ThoLe
ok damn, i didn't really want to wear their helmet w/ a bunch of people's sweat. I was going to use my friend's helmet.
From what I've seen you can get a DOT approved helmet fairly cheap at Walmart. BTW.. MIR is having test and tune today. You should go give it another try.
Old May 27, 2007 | 09:29 AM
  #32
TLe2006's Avatar
TLe2006
i already have plans today but i'll definitely go friday. you coming?
Old May 29, 2007 | 08:19 AM
  #33
TLe2006's Avatar
TLe2006
Should i change my transmission fluids or oil?
Old May 29, 2007 | 09:51 AM
  #34
IS_Mine's Avatar
IS_Mine
Why inflate the front tires?
I didn't do that when I ran my IS at the track. Deflated the rears to 28 psi, took out the spare tire, and had over a 1/4 tank of gas ran a 13.64 @ 101 with a 2.05 60ft.
Old May 29, 2007 | 09:57 AM
  #35
caymandive's Avatar
caymandive
11 Second Club
Inflating the front tires helps reduce rolling resistance. Don't over inflate, but pump them up to Max psi for the tire. I've done it every time, just make sure you bring the psi back to recommended when heading home.
THOLE..no you dont' need to change tranny fluids. As for engine oil, that needs to be changed every 5000 miles...and sooner if you drive it hard.
Old May 29, 2007 | 10:04 AM
  #36
IS_Mine's Avatar
IS_Mine
Have you done comparisons Cayman?
What does it save a 100th of a second to inflate the fronts?
Old May 29, 2007 | 10:14 AM
  #37
caymandive's Avatar
caymandive
11 Second Club
I don't have any controlled comparisons, but the few times I ran with stock front tire pressures, my trap speed was 1 to 1.5mph less each time. Theoretically this works.
Aug 9, 2018 03:27 PM
chrisfan
IS F (2008-2014)
14
Sep 10, 2013 07:36 AM
coolcow
May 3, 2007 07:52 AM
koreanpers
Dec 30, 2003 08:54 AM
