Will it fit?
Old Jan 20, 2007 | 08:24 PM
Gernby's Avatar
Gernby
Originally Posted by PhilipMSPT
Like putting "350" emblems on a "250," putting IS-F parts on the regular IS is very "wannabe."
That is like making a Lexus look like a BMW.
That is like making the IS look like the GS/LS.
That is like shouting out to all that "Hey, I can't afford the IS-F, but I'll be a Poser and pretend that I have bigger ********* than I claim..."
Don't do it.
Modify the car. Don't replicate another car...
I would agree if the OP was about putting emblems on a 250 or 350. However, if someone wants to put the "super bad-*** IS-F brakes" on an x50, why not do it?
Old Jan 20, 2007 | 08:28 PM
TLe2006's Avatar
TLe2006
I'm thinking of rotors/brakes and taillights.
Old Jan 20, 2007 | 08:45 PM
Ramon's Avatar
Ramon
CL Folding 1,000,000
Originally Posted by Turkf26
Why would swapping better brakes be lame?? IF you can get your hands on a seat of IS-F brakes, and they interchange perfectly, why would you not do it?? Granted it would probably cost more to get the IS-F brakes instead of some Rotoras or Stoptechs...
I suggest you re-read the original post. When you do, you will see that a brake upgrade was not the only thing that was mentioned. It should then be clearer to you that I was not refferring to a simple brake upgrade.
Old Jan 20, 2007 | 09:43 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by Gernby
I haven't "seen" them either, but someone on CL posted that their dealer installed eccentric lower control arm brackets to correct his alignment problem. If I remember correctly, the dealer either replaced his tires first without possitive effects, or they did the brackets instead of the tires.
I missed that thread. Got a link?
BTW, I'm extremely skeptical Lexus would do this. None of the necessary brackets are attached to the RWD subframe. I already dug into this one because I tend to kill the outer edges of my front tires before the rest of the tread. I thought it would be helpful to dial in more front camber, but it would take a huge effort and parts from some other platform (like a Supra.)
Old Jan 20, 2007 | 11:23 PM
Gernby's Avatar
Gernby
I don't have link, but I imagine it would come up if you do a search on "dunlop bracket alignment". I would do the search myself right now, but I've had WAY too many beers.
Old Jan 20, 2007 | 11:48 PM
kilo6_one's Avatar
kilo6_one
talk about being a poser, outside of the wheels go buy an IS-F if you want one so bad.
nikogio38
Jun 14, 2015 11:23 PM
ted920
IS F (2008-2014)
51
May 11, 2008 10:11 PM
weesped
Suspension and Brakes
Mar 16, 2008 12:10 AM
MSMLexIS
IS F (2008-2014)
Jan 26, 2008 04:09 PM
