Problem Fogging Up
Old Nov 27, 2006 | 01:35 PM
r4z0r3ck's Avatar
r4z0r3ck
Default Problem Fogging Up
Is it me or does the ISx50 have a tendency to fog up the cabins and especially the rear windshield fogging up easily. I've never experience a car fogging up so easily with the lowest outside temperature being 65 degree.
Old Nov 27, 2006 | 02:04 PM
pocky's Avatar
pocky
mooncake master
Nope, It's the same for all my previous cars. Never found the IS to have a problem with "fogging" up easy. I think you are just creating a bit extra "body heat" no?
Old Nov 27, 2006 | 02:06 PM
IS_Mine's Avatar
IS_Mine
My rear window doesn't fog up but my windshield does when I roll down my window then put it back up in the morning when I arrive at work. However, it quickly corrects itself. Maybe it is because of the temperature in you cabin?
Is your AC on?
Old Nov 27, 2006 | 02:25 PM
VikH's Avatar
VikH
CL Folding 200,000
You might have a residue on the window. My rear window is fogs easily because I am too lazy to twist my arm back there and clean it. Try cleaning it with a towel.
Old Nov 27, 2006 | 03:19 PM
r4z0r3ck's Avatar
r4z0r3ck
nope the ac isnt on but the seats are either heated or ac'd. but i think i mite have a defective rear windshield because i see a peeling/glue like effect throughout the windshield.
Old Nov 27, 2006 | 03:28 PM
AJA's Avatar
AJA
The seats are only ventilated. If there is a lot of moisture (generated by you and your passengers) inside the car, then the windows will fog up. You need to turn on your A/C.
Old Nov 27, 2006 | 11:01 PM
sashax415's Avatar
sashax415
I've had great success with a plain microfiber towel...
Old Nov 27, 2006 | 11:18 PM
r4z0r3ck's Avatar
r4z0r3ck
its so hard to clean the rear windshield with that bottom area.
Old Nov 28, 2006 | 07:02 PM
clubfoot's Avatar
clubfoot
Set the climate control to auto, leave the a/c on and it will do it's job of removing moisture from the air.
Old Nov 28, 2006 | 08:22 PM
Smoky350's Avatar
Smoky350
I also noticed that they fog easily. I've never had that problem with my previous cars but I have never had a sedan before either so I'm not sure if it's common with sedans.
Old Nov 29, 2006 | 01:01 AM
lexuspdx's Avatar
lexuspdx
I've only noticed it when driving Japanese cars. For some odd reason, you have to have the A/C unit on to prevent fogging. Not sure why. I think it was even in my old Honda manual. Haven't read the Lexus one yet.
I think you can push the front window defog button on the right side of the panel and it will automatically turn on the a/c and fans!
Old Nov 29, 2006 | 03:32 PM
clubfoot's Avatar
clubfoot
The a/c unit in our 2nd gen cars are designed to run all the time, it turns off automatically below freezing temps. The a/c unit will dry the air in the car and prevent fogging,...try it. Just leave it in auto (ON).
Mike552
Sep 19, 2017 01:34 PM
mcolommena
Aug 17, 2013 03:32 PM
jay33
Oct 6, 2009 05:12 PM
bfigard
Mar 27, 2008 04:00 PM
rgarjr
Automotive Care & Detailing
Jul 21, 2005 10:21 PM
