wheel size
Old Nov 18, 2006 | 01:54 PM
IStreefidy's Avatar
IStreefidy
Default wheel size
hey all,
im looking at a set of wheels, and I was wondering if I get 18x9.5 and 18x8.5 wheels with 5x114.3 lug size and 35mm offsets will work?
Also, what is the size of the stock wheels?
Thanks!
Old Nov 18, 2006 | 04:57 PM
Crazy Yoda's Avatar
Crazy Yoda
If you check out this thread it should help you.
https://www.clublexus.com/forums/sho...d.php?t=201509
Old Nov 18, 2006 | 05:15 PM
AZ IS350's Avatar
AZ IS350
I think the 8.5's will work on the front, although they will definitely be flush. The bigger problem up front is that some wheels don't clear the big brakes. 9.5's on the rear will definitely stick out beyond the fender. I say this because I have 18 x 8, 35 offset up front, 18 x 9, 35 offset in the rear. The rear on mine is flush, the fronts are slightly less than flush.
Old Nov 18, 2006 | 10:23 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
If you have trouble clearing the brakes with an 18" wheel, it's a pretty poor fitment. The car comes stock with 17" wheels.
Old Nov 18, 2006 | 11:23 PM
4TehNguyen's Avatar
4TehNguyen
theres more to it than diameter to enable a wheel to fit on a car with big brakes
Old Nov 19, 2006 | 06:37 AM
AZ IS350's Avatar
AZ IS350
I was implying that the style of the wheel/spokes may interfere with the brake caliper, not the size. Obviously, a 17 or 18 diameter works.
Old Nov 19, 2006 | 02:01 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I know. That's why I said poor fitment. I'm familiar with spokes hitting calipers. I'm also familiar with shaving calipers to clear spokes as is anyone who has put drag wheels on a stock MkIV Supra.
ace333
GS - 1st Gen (1993-1997)
May 19, 2017 01:57 AM
aau
Wheels, Tires & Brakes Forum
Aug 14, 2012 05:34 AM
IS350_PHIL
Apr 10, 2006 11:07 PM
goober
Jan 18, 2005 01:23 AM
nism0
Aug 10, 2004 11:56 PM
