Head gasket problem
Head gasket problem
I have been having a minor oil leak on the IS350 since new. I first noticed it around 2000 miles. Took it in and they find a metal line running from the pan up to the upper engine area that they thought was the problem (not the dipstick). I found more oil on the garage floor last week so I jack up the car and see the same line with oil on it. Took it back to Sewell thinking perhaps the fitting is leaking. Wrong! I get a call while eating lunch at Railhead BBQ and they tell me it is the head gasket. Needless to say my appetite went away after hearing that news. Car now has 5000 miles on it. Looks like it was the head gasket the whole time. Service advisor apologized for the problem and couldn't believe it had failed. Anyone else having oil leaks? The plastic pans under the engine had caught most of the leaking oil keeping me from discovering it sooner. Very disappointed!
Whoa, lemon law doesn't apply at this point. The dealer has several opportunities to fix the problem. From what has been described the dealer hasn't shirked its duties in tackling the problem, just misdiagnosed the problem. That's not surprising since you just don't hear of leaking gaskets on most modern engines these days. Let them redo the gasket and then keep an eye on it. If it leaks again there is a more serious problem with a warped head or block.
It's been several months since I've looked under the hood of my car, but over 18k miles on mine and no oil on the garage floor. I may pop the hood later tonight or tomorrow and take a closer look, but i'm pretty sure I'm ok.
I don't know if this helps anyone or if the 07 Camry V6 has the same engine as the new IS350, but I just took my 07 Camry V6 in for its first 5,000 mile oil change and was told then of an oil leak. I was told the front seal had to be replaced. I haven't picked the car back up yet, but hope this is the end of my problems.
Sorry to bring this up from the dead but i have a small oil leak on the right side valve cover and below it. It's not extreme but it looks like a sweat that would almost come from blow by pressure. Car has 120,000k. Anyone ever experience this problem? Thanks for reading
https://www.clublexus.com/forums/is-...l#post10057109
