New IS350 General Questions
So I figured out you can't order the Luxury Package and the X-Package together, so I was thinking what would be the best combination all together for that. Is the Luxury Package better?
yup.. and engine too.
Here in Dubai we only get IS300 which called IS350 in USA with the following engine spec :
* 3.0 Litre, 2995cc, 6 Cylinders, 24 Valve, DOHC, VVT-i, 3GR-FE
* Output - 228hp/6200rpm
* Torque - 30.6kg-m/4400rpm
Eritsuke, I think that you should ask your dealer about X-pkg and Luxury pkg..
The Sport package is basically the same as the Luxury except the Sport doesn't have wood, illuminated scuff plates, and rear sunshade. On the other hand the Sports package gives you the sport suspension, so instead of settling for the X-package you might find a compromise in the Sport. Has a bit of both from the Lux and X.
