View Poll Results: How long do you warm up you engine
None, start it and go!
305
36.40%
About 20 sec., until rpm drops to 1200.
321
38.31%
About 2 min., until rpm drops to 1000.
176
21.00%
However long it takes to get water temp up. (post what temp)
36
4.30%
Voters: 838. You may not vote on this poll
How long do you warm up your engine?
Old Mar 11, 2008 | 04:45 AM
  #196
Koz's Avatar
Koz
Originally Posted by Jaime55
If you have never tried driving a vehicle that sits outside all night at temps like this than you have no idea. Everyone here, including me, has engine block heater, oil pan heater, battery blanket, etc. but many times cars still don't start. I consider myself lucky enough to have a decent vehicle that I can keep running!
If you have a better suggestion, besides buying a new house with a heated garage, I am all ears.
You are using 0w-20 motor oil?
Koz
Old Mar 11, 2008 | 10:25 PM
  #197
ES3's Avatar
ES3
Where are we getting this? The owner's manual. Get in, start, drive away. The only thing it says is "don't race a cold engine." The car is ready to drive as soon as it has adequate oil pressure. That happens in about 5 seconds.
So you wait for 5 seconds before driving?
Old Mar 12, 2008 | 06:25 AM
  #198
nabbun's Avatar
nabbun
i just wait about 30 seconds to a minute or so until the oil cycles thru the engine couple times then warm up the car driving around for a few minutes. then after everythings warmed up, i have fun.
Old Mar 15, 2008 | 10:33 PM
  #199
LexusIS-TL's Avatar
LexusIS-TL
It doesn't hurt to take time to warm it up.
Old Mar 16, 2008 | 09:55 PM
  #200
lobuxracer's Avatar
lobuxracer
Tech Resource
If you don't mind the humidity inside the engine condensing and sitting on top of your oil with acids from combustion in the water that like to turn oil into gel, then you would be right.
You want to build heat in the engine. You can't build heat in the engine at idle within any reasonable period of time. Drive the thing. It will also move more air through the engine via the PCV system and help remove the humidity before it becomes condensation and works hard to ruin your oil.
Old Mar 16, 2008 | 09:56 PM
  #201
lobuxracer's Avatar
lobuxracer
Tech Resource
Somewhere between 5 and 10. Depends on how loud I left the sound before I got out.
Old Mar 17, 2008 | 07:29 PM
  #202
suicidesam's Avatar
suicidesam
i leave it running while i finish getting ready for work...and don't worry it's parked in a garage.
Old Mar 17, 2008 | 08:12 PM
  #203
elmerrox's Avatar
elmerrox
by the time i get my seat belt on and change the station, im good to go.
Old Mar 17, 2008 | 08:19 PM
  #204
Gernby's Avatar
Gernby
Your username says it all!
Old Jun 24, 2008 | 09:46 AM
  #205
LIS350A's Avatar
LIS350A
Originally Posted by tgara
Me too. My warmup is the half second or so that it takes my hand to go from the pushbutton starter to the gear lever.
I thought the manual says not to let the car warm up, just start it and go.
Me three.
My foot is on the brake as I step into the car. Press the start button with one hand, close the door with the other. Just as quick, one hand moves to shift, the other on the wheel.
Can't even use the back up camera. I'm in drive before the warning screen passes.
Old Jun 24, 2008 | 11:31 AM
  #206
Traumatic's Avatar
Traumatic
I just wait till the RPM drops, at least that will give the motor time to get oil flows and transmission components to get pressurized to function and less wear on the gears and engine components.
Old Dec 7, 2010 | 08:33 AM
  #207
MashinA's Avatar
MashinA
Default Do you let your car warm up before you drive it?
When your car has been sitting there for a day or two and you go to start it do you wait a couple minutes for it to warm up or do you just drive off? I dont know if thats a myth or not, but my dad always tells me i should wait for the engine to warm up.
Here are some more so called car myhts
http://autos.yahoo.com/articles/auto...ar-care-myths/
Old Dec 7, 2010 | 08:44 AM
  #208
Underoath's Avatar
Underoath
Nope. I fire it up, wait about 30 seconds, and I'm off.
Old Dec 7, 2010 | 08:55 AM
  #209
Phresh2010's Avatar
Phresh2010
i wait a min summer or winter
Old Dec 7, 2010 | 08:56 AM
  #210
IXI187IXI's Avatar
IXI187IXI
i usually wait about 30 seconds to a minute just for the fact im fiddling with my ipod or the radio.
