View Poll Results: How long do you warm up you engine
None, start it and go!
305
36.40%
About 20 sec., until rpm drops to 1200.
321
38.31%
About 2 min., until rpm drops to 1000.
176
21.00%
However long it takes to get water temp up. (post what temp)
36
4.30%
Voters: 838. You may not vote on this poll
How long do you warm up your engine?
Old Aug 24, 2007 | 05:46 AM
  #136
Gernby's Avatar
Gernby
Originally Posted by ERG
i take worming up very seriously, i even over do it. I start up the car let it worm up for like 10 minutes then slow drive it for like 5 minutes under normal temperature
Killing it with kindness (and ignorance).
Old Aug 25, 2007 | 01:27 PM
  #137
Perfection's Avatar
Perfection
i dont need to warm up my engine.
Old Aug 31, 2007 | 12:30 AM
  #138
inxexisten's Avatar
inxexisten
about 30-45 seconds...well in this summer heat the engine oil i bet is already fairly warm....maybe for the winter ill take a bit longer to warm it up
Old Aug 31, 2007 | 01:00 AM
  #139
is250manny's Avatar
is250manny
since its been so hot lately.
i've been starting my car and let it chill till im ready to leave. once im out the car has idled and its nice and cool.
the wait could be like 3-4min.
Old Oct 21, 2007 | 09:40 AM
  #140
CarlitosPR's Avatar
CarlitosPR
Thumbs up
Its a habit of mine to let it warm until the Needle on the engine temp. gauge reach mid-line after that ill let it have it!
Old Oct 21, 2007 | 02:40 PM
  #141
genki's Avatar
genki
i wait around 15-20 seconds when im in a rush. wait around 5 minutes when im not =) i baby it though until the engine is fully warmed up.
Old Oct 21, 2007 | 08:23 PM
  #142
BlackGhost's Avatar
BlackGhost
In The Winter Time About 3 To 4 Min,,summer About 2-3 Min
Old Oct 21, 2007 | 08:30 PM
  #143
kingofire's Avatar
kingofire
start the car, wait for the garage door to open ~10 seconds and vrrroomm
Old Oct 21, 2007 | 10:07 PM
  #144
y2ks2k's Avatar
y2ks2k
CL Folding Freak
CL Folding 1,000,000
5 minutes in the morning, the rest of the day if I fire it up, maybe 30 seconds at most.
Old Oct 21, 2007 | 10:11 PM
  #145
PNice972's Avatar
PNice972
start car then go, no wait
Old Oct 22, 2007 | 08:01 AM
  #146
Gernby's Avatar
Gernby
Idling is bad for an engine regardless of temperature!
Old Oct 22, 2007 | 08:12 AM
  #147
tex2670's Avatar
tex2670
I just hit the button and go (I haven't owned the car thru the winter yet, so maybe my answer will change).
Old Nov 3, 2007 | 12:13 PM
  #148
i3urton's Avatar
i3urton
wait 10 secs then go...
Old Nov 3, 2007 | 12:26 PM
  #149
LexusIS-TL's Avatar
LexusIS-TL
Man, you guys are rough. Rule of thumb is to wait until the idle lowers upon initial startup. Then go. The colder it is, the longer it takes for that to change.
Why is it bad?
Old Nov 3, 2007 | 09:44 PM
  #150
Lex Law's Avatar
Lex Law
Default The car works for me.
With my car, I go immediately if I'm ready to go. If it's cold and I have the time, I let the cabin warm up before getting in or while I scrape the ice and snow off the car. I have a 15 minute drive to work. I am more conscious about taking it easy when I first head out, until the temperature gauge goes to the middle and the warm air starts coming through the vents.
I read this entire thread about engine wear, and no one mentioned installing a system to start the oil circulating before the ignition starts the car. The most engine wear occurs when the oil's at the bottom of the engine and it's metal on metal at startup. Once you let that happen, the damage is done. I saw a mechanic on TV years back discussing it when he was demonstrating a pre-oiler.
Because I've only had my cars up to 150K miles and never had an engine that required major work or replacement, I don't worry about pre-oilers, warm-ups or the like. However, I never tear it up. Admittedly my cars have never had alot of HP: the IS250's 204HP is a big improvement over the 2 cars I've had over the last 20 years, '88 Civic (98HP) and '92 Sentra (110HP).
When my IS special order arrives, I'll treat it the same as the other cars I have driven, except I'll have to back off the gas pedal (partway ) due to the improved power, and I'll wash it according to some of the fanatical techniques learned at the Lexus boards.
I'm looking forward to Lexus putting out a remote start so I can warm it up in the winter in the morning before I leave the house and in the evening before I leave the office. I called Sewell yesterday, and they said it should be back as an option in 2008, maybe even before the next model year comes out.
