I do realise that these images doesnt show you how to install it, but at least you can go to Lexus and ask them for part #'s.
hth
b3dlam, I can see fuse #11 is for the rear fog, but can you check and see what color is on the wires for the rear fog? Also, what kind of bulb is using as the rear fog? Appreciate if you can give us some info, thanks.
The wires are red and black. The bulb is a Wedge base, rated at 21watts. From what i could tell, the bulb is the same one as the rear indicator/signal lights. Which would suggest the bulb base is the same.
