Personal Settings- Overriding?
Old May 24, 2006 | 12:59 PM
  #46
EBMCS03's Avatar
EBMCS03
Oh its not possible period on the IS. My bad. I thought he ment it had it before some type of setting he changed.
Old May 24, 2006 | 04:42 PM
  #47
kensteele's Avatar
kensteele
Originally Posted by Kermee
I think mr.BeboT is right. There may not be a way to do it and basically SOL.
I'm almost certain there's no way to set that behavior described above either via LPS or by the user.
Cheers,
Kermee
If people would just more clear about what they write, everyone would understand.
If the poster would have simply said "I understand you can unlock all doors with a simple grasp of the handle, but I'd rather have that option in a two step process...." then no one would be having this argument. Instead, most of the reads who come back to this post will certainily believe that you can't unlock all doors by grasping the handle. Because that is what he said. Which simply isn't true. But....
He said "The only big thing that bugs me now is how I can't press the door handle button to unlock all doors." No one is going to distinguish between the external outer button from the internal sensor, both on the handle. You statement may as well have said "The only big thing that bugs me now is how I can't grasp the door handle to unlock all doors.". Why? Because everyone knows that pressing the button can ONLY be used to LOCK the doors, there isn't even an function to UNLOCK using the "button." You would have been better off saying too bad I can first grasp the door handle to unlock the driver's door and then if I let go and grasp again, the next time all doors will unlock. Very confusing.
None of us know anything about a Mercedes so that really doesn't explain it.
Old May 24, 2006 | 05:12 PM
  #48
EBMCS03's Avatar
EBMCS03
Haha its ok... go easy on him after all he did help me get my 10 second unlock.
Its easy after the fact to think of what to write but many times at the moment it might sound perfectly clear in his head but isnt to others.
Actually I know some stuff about Mercs... my parents have one. I know even more about BMWs since I have one and always follow up on them ever since the E34s. and know more than you can imagien on the E39 M5 and just as much on the E60s.
Old May 24, 2006 | 05:23 PM
  #49
is4me2's Avatar
is4me2
Cool
Originally Posted by TimboIS
Yes you can. You can even make the change yourself. RTFM.
I'm still trying to figure out this acronym RTFM Is it "Read the Friggin Manual"?
Old May 24, 2006 | 10:05 PM
  #50
Kavistar's Avatar
Kavistar
hehe I have been wondering that myself but felt too stupid to ask....thanks :P
Old Jun 5, 2006 | 09:15 AM
  #51
linus523's Avatar
linus523
I'm still confused on setting the door lock/unlock feature. Could someone be kind enough to give me the exact steps on setting the door to
- lock when shifting away from P
- unlock when shifting into P
- lock when car reaches 13MPH
I know I should have read the manual (RTFM) first, but I couldn't find it anywhere in my Hong Kong edition manual. It didn't mention anything about setting the door lock/unlock feature...
If not, it would be nice if someone could send me the manual pages on this topic.
Thanks,
Linus
Old Jun 5, 2006 | 12:33 PM
  #52
Foxberry's Avatar
Foxberry
Originally Posted by EBMCS03
You know what. The search doesn’t work that well. Its hard to weed through so many threads. ESPECIALLY when 90% of them say RTFM or use the search. What help is that? Out of 100 threads that ask the same question. 80 of them say RTFM or "use the search, its been covered before" How will that help? First of all the searcher probably found the " 'Use the search' anwser thread BY using the search engine… If people don’t want to answer then skip the tread… don’t clutter the tread with useless answers.
The best way to do it is tell the poster to RTFM and also post an answer… otherwise skip it and go onto the next tread. Or tell the poster to use the search and SHOW them by linking it to a seached thread with the highlighted search word that you used to locate the tread that contains the answer. Its annoying enough to search and find so many threads on the same subject that’s been archived overtime but none of them contain the answer.
Its not a grief for everyone there are new members everyday who have not seen or even old member who have not seen new tricks. Just because couple people have seen it multiple times doesn’t mean everyone has seen it at least once.
Man, you are preaching to the choir on this one...
Old Jun 5, 2006 | 02:26 PM
  #53
Julez's Avatar
Julez
Are there any Personalized Settings that the dealer will do that aren't one of the 13 or so list, such as DRLs or some other type of setting
Old Jun 5, 2006 | 05:34 PM
  #54
EBMCS03's Avatar
EBMCS03
What do people believe already? That posting RTFM is the answer to all questions posted?
Old Jun 7, 2006 | 09:58 PM
  #55
Wid IS350's Avatar
Wid IS350
I'm going to read EVERY thread to answer the latest post. Your post said you can't unlock all the doors by touching the drivers handle. You can if you bothered to read the manual, it's clearly explained how to do it. Would you have understood RTM? Probably not, RTFM is just an expression. Get over it.
PS. Meybe it's just me, but I get VERY tired of people asking the same questions, or complaining about the same things, over, and over, and over. Search would avoid a lot of this grief for everyone.
Yikes... someone needs to pick up their xanex prescription at the pharmacy! And while you're at it - lay off the caffeinated beverages.
It takes WAY too much energy to complain that much.
clubsport
GX - 1st Gen (2003-2009)
Feb 10, 2012 05:07 PM
kindred6ul
CL of Southern California
Aug 29, 2007 04:58 PM
CAIFAN_64
Mar 9, 2007 12:16 AM
Mikjr
RX - 1st Gen (1999-2003)
Aug 22, 2004 08:44 PM
