Lexus IS350 on 20" ADR Sterling Staggered
Old 02-28-06, 05:42 AM
blkonblk17
blkonblk17's Avatar
Default Lexus IS350 on 20" ADR Sterling Staggered
Tires
Front - Nitto 555 - 225/35/20
Rear - Nitto 555 - 275/35/20
Wheels are ADR Sterling
Front 20x8.5
Rear 20.9.5
Pics
Click on picture to enlarge it once opened click picture again to enlarge full size.
Old 02-28-06, 05:49 AM
4TehNguyen
4TehNguyen's Avatar
looks great! if you have a few minutes can you enter your setup in this thread, trying to compile a reference list of aftermarket wheels for the IS. So we dont have all these will these fit, what offsets, will i rub threads. Thanks!
https://www.clublexus.com/forums/sho...d.php?t=201509
Old 02-28-06, 06:19 AM
blkonblk17
blkonblk17's Avatar
Wheels are 5x114
I believe the front's are 35 offset and the rear 38.
When I have two passenger etc on rear seat accompanied with passenger front on well on highway when I get a bump I hear the rear rub again the outer fender (the part that people usually roll) but makes no damage to tire or car its self, you just hear it rub when you get a hard bump.
And in the front when you turn in about 90 degree angle it rubs against front wheel well plastic which i got a heat gun to push the plastic a little bit in to get rid of this problem. I remember another member on the forum with 20" doing it as well.
Hope this helps
Old 02-28-06, 06:41 AM
tim817
tim817's Avatar
Originally Posted by blkonblk17
Wheels are 5x114
Hope this helps
To elliminate the rear rub, i recommend you to change your rear tire to 275/30/20 the next time you replace the tire. It'll be closest to stock diametter. Since the IS350 are RWD, they're using the rear to calculate speedometter. The 275/35/20 diametter are bigger than stock so the speedometter will be inacurate. If your speedometer reads: 65 You're going approximately: 68.87. Here is the link for tire calculator: http://www.discounttire.com/dtcs/infoTireMath.dos
I have 275/30/20 with a higher offset: +43 and never had rear rubbing problem.
Old 02-28-06, 07:05 AM
4TehNguyen
4TehNguyen's Avatar
excellent, ive updated my aftermarket wheel setup thread with your setup and some of the comments posted so far. Thanks a bunch, nice setup
Old 02-28-06, 07:23 AM
ecr527
ecr527's Avatar
Nice wheels! I'm loving the deep dish rear wheels.
Old 02-28-06, 07:51 PM
Redpaste
Redpaste's Avatar
not really a fan of chrome, but that looks really nice and clean. great job!!
4tehNguyen, just wanted to say your doing a great job with your wheel setup thread. dont think its going unnoticed. Im sure a lot of members appreciate it as I do
Old 03-01-06, 06:36 AM
blkonblk17
blkonblk17's Avatar
Correction, My rear tires are 275//30/20
Sorry for the mix up
GetUrWheel
Club Lexus Vendor Marketplace
161
01-16-14 08:12 AM
Lexura1414
Wheels and Tires Classifieds
13
10-12-12 08:23 PM
gride888
04-29-07 12:31 AM
blkonblk17
03-28-06 12:52 AM
Quick Reply: Lexus IS350 on 20" ADR Sterling Staggered
