IS 350 vs Winter
Old Jan 16, 2006 | 05:33 PM
sajonf's Avatar
sajonf
I have a set of Blizzak LM25s in the stock sizes on my original 18" wheels. I have encountered snow twice this winter and had no problems at all. I actually felt quite confident.
Old Jan 16, 2006 | 05:37 PM
sbkim's Avatar
sbkim
Originally Posted by heffergm
The diameter of the wheels is going to have little to do with snow tire performance. What matters is the tire width. The narrower the better. You want to cut THROUGH the snow, not ride on top of it. The wider the tire, the more of the cars weight is distributed over that contact patch and the more you're going to ride on top of the surface rather than go THROUGH it.
The key is narrow tires. Go watch a WRC snow rally event. They run on about a 150 series tire. Admittedly they also have spikes in them, but the physics holds true regardless.
What size tires would you recommend for 18"?
Old Jan 16, 2006 | 05:49 PM
Bichon's Avatar
Bichon
Originally Posted by dkaplan435
I have Blizzak LM25's on the 18" wheels that came with the car. The handling in snow is a bit iffy... Ok.. but take the turns carefully.
I should have purchased 16" or 17" wheels/tires...
I concur. My Pirelli snows in the original 18" size are barely adequate, and that's in a storm that only dropped 2". Tire Rack doesn't have 16" or 17" winter packages, but the dealer outght to be able to put something together. With the right wheels, you could run 205/55-16s -- IS Lover from Ontario (where they get lots of snow) reports in the thread I started yesterday that Toyo snows in that size on his IS350 make the car handle snow like it's on rails.
Old Jan 16, 2006 | 05:57 PM
tqlla3k's Avatar
tqlla3k
Yeah, and we all know how fierce VA winters are... driving your car through the winter months on summer tires isn't the same as driving your car through the winter months with summer tires when there's actually snow on the ground
Look, I'm not trying to offend. Obviously you're entitled to your own opinion, but as a New England native, the last advice I'd give anyone is to leave their summer tires on the car if they're expecting snow, AWD or otherwise.
Obviously, regardless of tire type in the snow, AWD > FWD > RWD. But that doesn't change the fact that summer tires offer precious little grip when it's cold and snowy.
I didnt say that I was expecting the RWD car to drive through mountains of snow. I said the car was practially undriveable with some slush of snow on the ground.
The Snow tires that you think will be a miracle is not a replacement for a more suitable drive type. I just dont want to get the OPs hopes up.
Old Jan 16, 2006 | 06:09 PM
Bichon's Avatar
Bichon
Originally Posted by tqlla3k
I actually think you are trying to offend otherwise you wouldnt be talking down to me like that. Or like you did in the previous post. I didnt say that I was expecting the RWD car to drive through mountains of snow. I said the car was practially undriveable with some slush of snow on the ground.
AWD or FWD will get you going, but it won't help you stop. I've been reading Audiworld for the past six years, and EVERY winter I read a couple of stories from people who thought they'd be okay with AWD and summer tires, but were now asking for recommendations on a good body shop.
Old Jan 16, 2006 | 07:03 PM
tqlla3k's Avatar
tqlla3k
Yes, that is true, but the Drive type will help sure you maintain control while accelerating and turning. Which are also pretty important.
I would never recommend summer tires in the snow, but I also wouldnt suggest that RWD with snow tires will be as good as FWD with all seasons.
I also wouldnt suggest that FWD with snow tires would be as good as AWD with all seasons.
Basically, I am saying. Dont get your hopes too high. I doubt that the IS350 with winter tires will be as good as an Accord or Camry with all seasons. If that is what the OP was wondering.
Old Jan 17, 2006 | 08:21 AM
shaolin's Avatar
shaolin
do NOT drive your IS350 if you have stock tire and no chain.. you will not get out.
i just go back from Tahoe yesterday and it was snowing.... i can not even move out of my driveway. i see civic drive by with regular m/s tires...
i got chain and make sure you practice them on first before you go up there...
i'll post some pic later this week of how the chain look on the car...
Old Jan 17, 2006 | 08:22 AM
shaolin's Avatar
shaolin
if you live at a place with snow all the time.. get the awd and some snow tires.. you'll be good
Old Jan 17, 2006 | 09:48 AM
SilverBolt's Avatar
SilverBolt
Not true. A taller sidewall is a big benefit in a winter tire. Narrow is correct but a stiff short sidewall won't help any. I doubt a 16" wheel will clear the rotor/caliper so a 17" is probably the best bet.
Old Jan 17, 2006 | 09:53 AM
SilverBolt's Avatar
SilverBolt
FWD snow traction is an outdated claim. In the early FWD cars they were heavily weight biased to the front. Modern FWD cars have the weight more enenly distributed so the traction benefit is gone. If anything a modern FWD will be worse in the slick stuff. Two hypothetical cars. Both with 50/50 weight distribution. One FWD and one RWD. With the FWD when the drive tires lose traction and begin to slip you also lose steering control.
Old Jan 17, 2006 | 10:14 AM
Bichon's Avatar
Bichon
According to IS Lover (post #3 in this thread: https://www.clublexus.com/forums/sho...d.php?t=196168) he has 16" wheels on his car. So with the right 16" wheels they should at least clear on a base IS250. (A quick check of lexus.ca shows that 16" wheels are standard from the factory on RWD IS250s in Canada) Wouldn't be surprised if the IS250AWD and IS350 have bigger rotors, so what you say may be true for those models.
Old Jan 17, 2006 | 10:17 AM
tqlla3k's Avatar
tqlla3k
Hmmm, maybe things have changed since the 90s. But not so certain. I thought the advantage of FWD is that you are pulling the cars weight, instead of pushing the weight.
In your Hypothetical. Yes, it is bad to lose traction on your drive tires, but not as bad as losing traction to the front tires in an RWD car. In an FWD car, the Front tires Warm up quicker which makes them less likely to lose traction. Also, when you lose traction in your front tire in an FWD car, you dont ususally spin out.
You will probably continue in the direction your car was going.
An RWD car is much worse. If your front tires lose traction, but the Rear tires still have power, then you will likely spin out.
Old Jan 17, 2006 | 12:16 PM
Bichon's Avatar
Bichon
A quick Google of some recent FWD reviews leads me to believe that the average weight bias for front drive cars these days is more like 60/40, not 50/50. For example, in our own marque, the Lexus ES330 is front biased 61/39. For the Acura TSX, it's 60/40 for the manual, and 61/39 for the automatic.
On your other point, I think it is actually worse if the rear wheels lose traction than the front. When the rear wheels let go, the car will oversteer, which is far less intuitive for an untrained driver to correct than understeer.
Old Jan 17, 2006 | 12:53 PM
1loudLX's Avatar
1loudLX
Our LS with the optional tire size of 245/45/18 with michelin All seasons wasnt what I was hoping for in the snow. I swapped back to the orginal wheels with the standard Dunlop 225/55/17s and it was a little better (tried both within a few hours of eachother on the same snowfall).
If your concerned about really treking through the snow then consider a GX or LX. If you just need to get around in the winter when its snowing, a good set of thin(tire width) All season tires or winter tires is the ticket. With a little extra weight in the trunk, a dead body works great, and decent tires that are designed for snow should be able to get your IS350 around. I think you should buy the IS350, i mean they do have plows in chicago right?
Snow driving puts a smile on my face...its fun.
Old Jan 17, 2006 | 01:19 PM
SGT's Avatar
SGT
Dumb question, but why does extra weight in the trunk help in snow driving?
