Missing transmission filter bolt
Old Feb 5, 2025 | 01:11 AM
R2ISED's Avatar
R2ISED
1st Gear
Default Missing transmission filter bolt
Hello!
I was about to service the transmission a few days back with the usual drain and fill procedure that everyone does. I have done it before so I am familiar with how it works, only this time i wanted to change the transmission filter aswell.
I removed the old filter, which had four bolts attached to it, and replaced it with the new filter, which should be torqued down to 7 ft-lbs. The problem is that I accidentally used the wrong torque wrench and snapped one of the bolts holding the filter to the transmission, only one
My question then is, will the filter be fine with only 3 out of 4 bolts?
Kind regards Rasmus
Old Feb 5, 2025 | 11:37 AM
mandyfig's Avatar
mandyfig
Go get a replacement bolt. Take the a bolt and show it to the store, cheap item. Next time read instructions carefully on how to use a torque wrench. Good luck.
Old Feb 5, 2025 | 11:38 AM
2013FSport's Avatar
2013FSport
Originally Posted by R2ISED
Hello!
Kind regards Rasmus
It could be okay, but it could also vibrate and potentially crack leading to it sucking air and killing your trans.
Bolts - watch them, when they stop turning, something has to give. At least it didn't strip. Id find a new bolt.
hydrogenfu
Jun 7, 2024 01:37 PM
professorm
Sep 15, 2021 05:50 PM
Ham
Mar 22, 2021 02:46 AM
brian1980
RX - 1st Gen (1999-2003)
Apr 25, 2015 08:54 PM
blacksedan
Feb 21, 2013 08:26 AM
