Door lock actuator going bad or something else?
My 06 IS350 has started beeping multiple times when unlocking, I posted a previous thread looking for answers. Pulling the negative terminal off the battery worked for a little bit, but now I've noticed since the cold weather has hit, my right rear door does not lock and unlock and I press the lock and unlock button. I am also unable to open the door with the door handle from the inside when its locked. I have to manually unlock the door from the inside, then use the interior handle to open it. I've also notice that the door lock barely moves when I lock and unlock the doors.
Could this be the door lock actuator failing? I also can't understand how the actuator ties into being able to unlock the door by simply pull the interior door handle.
BLK98GS3
Jun 3, 2012 07:25 AM
Chris98vob
GX - 1st Gen (2003-2009)
Mar 3, 2007 09:19 AM
