Engine stops, no crank, lights work
Old Jan 20, 2025 | 07:08 AM
oxlacey's Avatar
oxlacey
Default Engine stops, no crank, lights work
Got about 2 blocks from my house this morning in 14 degree weather in Alabama and engine died. Car wouldn't crank. Lights work. Got a jump from a passing car (thanks!). I have a lighter voltmeter, it read 11.9volts. When he jumped car, it still read 11.9volts. My car still wouldn't crank. Tried 2nd key fob, no difference. What should I look for?
Old Jan 20, 2025 | 07:31 AM
mandyfig's Avatar
mandyfig
Your battery dead 1, If it is dead, you might have an alternator issue. Or else a dead or dying battery. How old is the battery? If 3 or more years or older, battery could be it, good luck.
Old Jan 20, 2025 | 07:53 AM
oxlacey's Avatar
oxlacey
Thanks for the quick response. New AGM battery (last fall). Doesn't make sense that car voltage didn't go up when I was connected to the jumper car. Now my son is at the car and it started right up for him!
Old Jan 20, 2025 | 07:56 AM
oxlacey's Avatar
oxlacey
OK, my son said it started then died. Weird. When I get it to the house I'll put a meter on the battery and then slow charge the son of a gun. Been on slow charge for 30 minutes. Now I hear a couple of faint clicks when trying to start. Guess I got a dud Optima battery? Will know at the end of today when temps reach a balmy 24.
Old Jan 23, 2025 | 05:41 AM
mandyfig's Avatar
mandyfig
Sounds like a starter failure. Battery is good, there is gas, so it should crank. Good luck with your debug.
Old Jan 24, 2025 | 07:20 AM
oxlacey's Avatar
oxlacey
removed cover from immobilizer and hit with hair dryer. car starts/runs like a champ. go lexus!
Old Jan 24, 2025 | 10:25 AM
2013FSport's Avatar
2013FSport
But is it charging? AGM's typically have a slightly higher static voltage compared to regular LAB. My USB volt meter in the IS and Tundra pretty .uch always show 13.9 to 14V on start and hold that for about 15" and settle to 13.4 - 13.6V until shut off.
Old Feb 5, 2026 | 12:31 PM
oxlacey's Avatar
oxlacey
sure thing, alt is doing it's thing and charging the agm battery. all is well.
radiologym
Apr 27, 2023 03:45 AM
sheikhmax
LX - 3rd Gen (2008-2021)
Nov 2, 2021 08:38 PM
Trbltrbl
Mar 15, 2015 05:57 PM
Karlos
IS - 1st Gen (2001-2005)
Feb 23, 2009 06:16 PM
digitldiva
Aug 15, 2006 07:59 AM
