Transmission and Diff Questions
Old Dec 3, 2024 | 07:59 AM
2IS6Speed's Avatar
2IS6Speed
1st Gear
Default Transmission and Diff Questions
So, to preface this question, I know that what I'm about to ask has been dragged back and forth through the mud on these forums. However, a lot of what I'm reading was people still confused back in like 2006-2013 while these cars were still being manufactured.
I recently bought my car from an elderly couple (2007 Lexus IS250 Manual, 244,000km's), the vehicle itself is in immaculate condition but I'm not sure they've kept up on Tranny and Diff fluid changes at all. Now, depending on which forum I read some people say not to touch the Diff fluid at all, while others say there is an interval for it depending on if you live in Canada or USA (I live in Canada). Unless someone tells me different, I'm probably going to go forwards with replacing both fluids.
Then there is the argument of Mobil-1 vs. Amsoil vs. Royal Purple.
My Question is;
If I were to change my Transmission and Diff fluid am I okay to use Amsoil Severe-Gear 75w-90 Synthetic for both? or Should I use Severe-Gear for the Diff and Mobil-1 75w-90 Synthetic in the transmission?
Apologies if this is a loaded question, I'm just genuinely confused with everything I've read.
Old Dec 3, 2024 | 02:27 PM
Inactive's Avatar
Inactive
My Question is;
No clue on the diff fluid but I use Toyota Genuine ATF WS for my transmission fluid as directed by the owners manual
Old Dec 3, 2024 | 02:40 PM
MikeFig82's Avatar
MikeFig82
For the diff 75w-90 synthetic of your choice. Mobil, Amsoil, Royal Purple. The butt dyno all feels the same.
I've ran those on an IS250 AWD front and back diffs. On the GS350 I'm currently running Amsoil.
Old Dec 4, 2024 | 05:14 PM
primavera's Avatar
primavera
See here...
https://www.amsoil.ca/lookup/auto-an...ode-4gr-fse-h/
Old Jan 11, 2025 | 02:17 PM
Jeeves250's Avatar
Jeeves250
The diff oil definitely needs to be changed. Over time, any oil will lose its lubricant and detergent properties. I bought the Toyota stuff from the Lexus dealer, but have also used whatever Canadian Tire had that was vaguely the same weight (it's hard to find the 75W85 that is specified - usually, you can find 75W90 in retail stores). But yeah, change them both! And make sure you get new crush washers, and always start by undoing the fill plug (much easier to deal with a stuck fill plug before you drain the transmission!)
Old Jan 13, 2025 | 02:01 PM
2013FSport's Avatar
2013FSport
It appears OP has a MT.... these do not use ATF.
OP - just make sure the fluid in the gear box is fully compatible with brass as not GL-5 fluids are backwards compatible with GL-4 which typically goes in a MT.
Old Jan 13, 2025 | 02:04 PM
Inactive's Avatar
Inactive
My bad I didn’t see it
carsareus
ES - 7th Gen (2019-2025)
Apr 23, 2024 09:40 AM
OceanView
15
Jul 13, 2019 04:41 PM
tudank
Apr 6, 2018 08:59 AM
nk1983
Maintenance
Sep 3, 2004 06:01 AM
96sc3
Maintenance
26
Feb 20, 2004 05:54 AM
