Car shuts off all electronics after trying to start
Old Jun 9, 2024 | 08:29 PM
emperor651's Avatar
emperor651
10th Gear
Default Car shuts off all electronics after trying to start
As said in title, the car shuts off everything when i try to start it. Sometimes when i step out of the car it will enter accessory mode and ill try to start it again and it will do the same thing. Then randomly it will start for me. I believe its the bcm, so i was going to buy a used one but i am wondering if possibly the bcms are vin specific so i will have to buy a brand new one?
Old Jun 10, 2024 | 09:33 AM
2013FSport's Avatar
2013FSport
Have you had the battery and alternator load tested? If the battery /system voltage is unstable, the computers lose data and all kinds of strange things happen.
Old Jun 10, 2024 | 01:48 PM
timmy0tool's Avatar
timmy0tool
agree that the alternator is a known issues which contributes to your symptoms. another known issue is the fuel pressure sensor if the batter/alt checks out.
Old Jun 10, 2024 | 05:21 PM
emperor651's Avatar
emperor651
10th Gear
thank you for replying, unfortunately i tried the battery and alternator testing and it seemed fine. It doesn’t shut off when im driving, after i get it to crank it runs totally fine. The issue is when i get into my car and try to start it, when i press on my brake the light pops up on the keyless start, but as soon as i press it everything turns off, even the dome lights. Its almost like the car thinks its stolen.
Old Jun 10, 2024 | 05:22 PM
emperor651's Avatar
emperor651
10th Gear
It could possibly be the fuel pressure but check what i said to the previous comment if you might need more context.
Old Jun 10, 2024 | 06:35 PM
2013FSport's Avatar
2013FSport
Sounds like you have a bad connection and how were these other tests performed? Look close at all large cables. Chances are, one is compromised.
I'd still suggest a battery load test. If nothing else, disconnect the leads and clean them.
Old Jun 12, 2024 | 01:05 PM
Protholl's Avatar
Protholl
Is the check engine light on when its in this condition? Have you looked at the ground strap that goes from the battery to the engine block? Have you done a voltage drop test from the battery negative to the engine block, the frame and the chassis? I remember another user had an issue with the ground strap where it was rotted badly at the opposite end from where it connects to the battery and it caused intermittent issues like you are talking about.
Old Aug 5, 2024 | 06:58 PM
emperor651's Avatar
emperor651
10th Gear
sorry for the late response, but i have figured it out and it was the fusible link. Got a replacement on ebay and installed it myself.
BlazeViper
Apr 14, 2025 06:53 AM
sveinongen
May 5, 2020 07:47 AM
JNew
Nov 20, 2007 08:06 AM
