Replace a 2006 Nav with 2010-2012 Nav?
Old Feb 1, 2024 | 09:32 PM
Inactive's Avatar
Inactive
Default Replace a 2006 Nav with 2010-2012 Nav?
I got a 2006 IS350, I'm thinking about buying an OEM 2010-2012 Nav and replacing my current 2006 one with it. I mainly just want bluetooth and better voice commands. Does anyone know if this is possible? Has anyone here tried this or have a link to a thread where this was done? Pictures of a finished product even?
Old Feb 2, 2024 | 01:17 PM
Protholl's Avatar
Protholl
I'd bet that will not work because Lexus/Toyota radios are year specific. If you already have a NAV radio for your 2006 you are better served looking at something like a grom V2.
Old Feb 3, 2024 | 07:31 PM
Zmon's Avatar
Zmon
I looked into it a long time ago when I first bought my car, there is way too much wiring work involved + the cost/time of the new HU makes it simply not worth it.
I wouldn't bother worrying about voice commands unless you have something that supports Siri or Google Assistant, which I believe you'd need Grom's Vline for Carplay/Android Auto. If you don't care about carplay/aa, you can just get their BT3 module. I personally went with the BT3 module as I got tired of the wires. BT quality is fine on it. You can use it with the car's existing bluetooth so the end call/answer call buttons will still work, you just have to make sure your phone is connected to the car first then connect to the grom module.
Old Feb 3, 2024 | 07:55 PM
Inactive's Avatar
Inactive
i was planning on picking up the newer nav and paying an electrician to figure it out, if it didnt work they could always put the old one back in, and i could send back the newer one back. if it failed i wouldn't be out of that much money, but if it did work it would be history in the making
Old Feb 4, 2024 | 08:24 AM
AmyUD06's Avatar
AmyUD06
Hate to break it to you, but the "voice commands" in my 2011 system at least are so extremely lacking that I never use them.
Old Feb 4, 2024 | 08:44 AM
Tkilgore72's Avatar
Tkilgore72
2nd gear
I don’t know how to post to here but my Lexus RX 300 is kicking the knock sensor code and Oil control valve code I replaced all of them and it’s still kicking the code it sounds like there is a leak on the valve somewhere between the gas tank and engine. Has anyone ever experienced this isssue?
Johnny
Apr 20, 2007 06:41 PM
jiggyman
Oct 21, 2005 12:17 AM
