Low ltft and stft in idle
Hi guys, i have a is250 2007 with 230k km on it. It has a intermittent problem of hesitation and loss of power. Both of my short term fuel trims are close to -20 when idling but as soon as i accelerate it goes between +5/-5. My long term fuel trims are both close to -20 as well.
Changed spark plugs
Changed fuel pump
changed injectors
Any ideas?
thanks
Changed spark plugs
Changed fuel pump
changed injectors
Any ideas?
thanks
Having experienced this with my Fsport lower air box. Once the MAF readings get out of wack. Both STFT, and LTFT will read -20% rich. This was happening because my air filter was getting saturated with water.
You have to wipe the ECU fuel trims to a clean slate.
Did you disconnect the battery when doing all this work?
I'd start with geting a new air filter if milage is unknown, and cleaning the MAF with CRC MAF Cleaner
ECU Reset: To me the fuse method is the easiest.
https://www.clublexus.com/how-tos/a/...our-ecu-363500
After the reset the LTFTs should start off at 0. Then monitor the trims.
thanks
@MikeFig82
Help me out here but I think a vacuum leak results in positive trims while a bad o2 sensor(s), plugs not firing, result in negative trims as the ecm is pulling back fueling.
If this were mine;
Monitor the following:
MAF and O2 sensors using obd port and software.
Check for exhaust leaks.
If plugs are past 75k miles, replace them and inspect for carbon build up in intake ports. No air or starved for air means negative trims.
That's what comes to mind initially.
If this were mine;
Ideal1267
Dec 24, 2005 01:24 PM
