Lights randomly On
Old Dec 7, 2023 | 02:47 PM
trdblackis's Avatar
trdblackis
Veteran: Army
Default Lights randomly On
On my way home, my ABS light came on and the AFS OFF flashing light came on. Then about 20 minutes later it went off. Anyone know what the issue could be?
I did recently change the rear sway bar.
Old Dec 8, 2023 | 12:19 PM
2013FSport's Avatar
2013FSport
AFS and ABS have little in common. Any recent creek crossings / highwater?
Old Dec 8, 2023 | 04:27 PM
Protholl's Avatar
Protholl
Has the brake fluid ever been replaced?
Old Dec 11, 2023 | 08:09 AM
trdblackis's Avatar
trdblackis
Veteran: Army
No water crossings. Avoid them if I see them or go slow.
Old Dec 11, 2023 | 08:10 AM
trdblackis's Avatar
trdblackis
Veteran: Army
Changed maybe 2 years ago
Old Dec 11, 2023 | 02:57 PM
2013FSport's Avatar
2013FSport
You need to take it to an auto parts store and get the codes read, then we will know where to look. For now, inspect the left front and rear suspension by following wires to a sensor mounted on the body. The ride height sensor has an arm that connects to the suspension. The front one connects near the sway bar mount to lower arm. The rear to a bracket on the lower control arm. It's really tiny ball-joints to the sensor compared to the suspension parts it's keeping track of.
The sensors arm has a slot for adjusting the arms position in relation to suspension positions. Make sure they are there and connected. If possible, do this while the vehicle is at ride height vs wheels hanging down.
Left front is visible by turning the wheel. Rear might be visible through the wheel depending on the wheel.
doczeeuk
RX - 5th Gen (2023-present)
Nov 20, 2023 01:21 PM
Burroo67
Nov 8, 2018 03:50 AM
wgrussell
GX - 2nd Gen (2010-2023)
Dec 17, 2017 07:03 AM
sparta3993
Aug 18, 2016 11:34 AM
robertrios
May 21, 2014 01:29 PM
