Turn signals not flashing when locking but flashes when unlocking
Old Dec 2, 2023 | 09:51 AM
james250's Avatar
james250
Default Turn signals not flashing when locking but flashes when unlocking
I have a strange issue. When I go to lock the car, either by pressing the door handle switch or key lock, The turn signal lights dont flash as they used to. But when unlocking they do flash. However when locking there is definately something going on because I can hear the car lock then immediately after it has locked, I can hear its almost like it tries to lock again.
Any idea what I can check?
Old Dec 3, 2023 | 11:04 PM
jedan's Avatar
jedan
Do they blink 2 times when unlocking? Do all the doors lock / unlock properly? Also, for every door, check if its locked immediately after you press the lock button, before you hear that second sound. Then try holding both lock and unlock keys for few second to change the all doors / only driver's door unlocking mode. That changes how the circuit works, so see if that changes anything. Then try your standard disconnect-the-battery procedure to reset the ECU.
Old Dec 4, 2023 | 12:37 AM
Yodog's Avatar
Yodog
this true on the 2is? I did not know this if so… (thank you)
BillWill87
GX - 2nd Gen (2010-2023)
Apr 9, 2022 04:27 PM
Jessek1486
Oct 27, 2018 08:00 PM
kayyjohnst
Jul 1, 2017 03:28 PM
McKrevice
Apr 8, 2010 10:06 PM
mikevanle
Nov 30, 2007 06:03 PM
