2012 is 350 fog lights help
I purchased this vehicle a couple weeks ago, no problems at all besides fog lights not being on. When I push the fog bottom by my dash , I notice not only don’t the fogs not turn on but my headlights flicker and go back to normal. Before I purchase new fogs to see if that will work, anyone know wat the issue can be ?
You might want to look under the dash and at and headlight relay module in the engine bay and see if anything looks out of place. I'm guessing someone added this and modified the car wiring.
I'm 99.99999% you're hitting your headlight washer button instead of your fog switch, which as stated, is on the turn signal stalk as an additional ring inside of the outer headlight-twist option.
I swear, does no one one check owners manuals anymore?
You completely missed the fact that the OP said they were "pressing the fog light button on the dash" (which is not where the fog light control is) and that the "headlights flickered" as it would appear if the washer was spraying them.
