Advics - lost part
Old Apr 19, 2023 | 09:31 AM
LP350's Avatar
LP350
10th Gear
Default Advics - lost part
Hi,
looks like i lost nut/insert from is350 Advics brake caliper, do you know please replacement or PN?
Thanks for help!
Old Apr 19, 2023 | 02:01 PM
2013FSport's Avatar
2013FSport
Originally Posted by LP350
Hi,
Thanks for help!
You missing the whole bolt?
4X needed up front for caliper retention.
PN 90119-12415 12-1.25PX45-30
Old Apr 19, 2023 | 02:54 PM
LP350's Avatar
LP350
10th Gear
Unfortunately no bolts, but these inserts see on picture
Old Apr 19, 2023 | 03:04 PM
Those inserts are not shown separately available in the parts diagram.
http://www.japan-parts.eu/lexus/us/2...per-dust-cover
Old Apr 19, 2023 | 10:07 PM
LP350's Avatar
LP350
10th Gear
Somebody any idea how to replace it or have extra?
Thank you again...
Old Apr 20, 2023 | 12:42 PM
2013FSport's Avatar
2013FSport
Thank you again...
Although that caliper looks like a standard caliper used on many 350's, that is not normal in the US with that tiny pad and IIRC ours do have that insert on there (the part you are missing). Can you confirm which end of the car that is for? Our rear caliper is a floating caliper reliant on a single piston and guide pins but the pad is about that size.
What region is your car from? I suggest buying a used caliper from your region.
IS-350 US spec front caliper.
I looked at our service kits and that is not a service item.
https://www.rockauto.com/en/catalog/...dware+kit,1736
You may find it on any used 350 or even GS-350 front caliper though.
Old Apr 20, 2023 | 01:29 PM
2013FSport's Avatar
2013FSport
OP, another option is anyone in a machine shop with a lathe could make this in 15 minutes. Maybe faster if you hand them a spare.
If sized properly, it will have a slight interference fit into the caliper and not come out. I suggest permanent thread locker be applied once you confirm it seats fully, pull it apart and apply it, assemble and torque to spec.
GL
Old Apr 20, 2023 | 02:13 PM
LP350's Avatar
LP350
10th Gear
Thank you for feedback, I'm located in Europe, so qty of spare parts is lower against US market.
Missing is from front caliper, both. Service guy put them away unfortunatelly when ISF been installed on car.
Anyway I think that last option you mentioned will be best cause this part isnt spare part unfortunatelly...
Again thank you for help, will let you know how been made, if someone will come with similar issue.
Old Apr 20, 2023 | 03:44 PM
2013FSport's Avatar
2013FSport
Its basically acting as a nut for the bolt and its steel so it won't strip.
What are you saying about IS-F? Are you trying sell these as you upgraded?
Old Apr 21, 2023 | 10:09 AM
LP350's Avatar
LP350
10th Gear
Yes, upgraded and service guys lost original nuts on one I sold... so trying to help to find solution....
looks like other nut or like last posibility donor caliper.
Cheers​​
Old May 22, 2023 | 12:22 PM
nitroracer's Avatar
nitroracer
Anyone know if these are reusable? The service manual doesn't say anything about one-time use or replacing. It also doesn't mention if/where to put any grease (onto the hub face behind the rotor, eg). I guess this is obv some should go there, just found it curious since the service manual is littered with references to their red rubber "lithium soap base glycol grease".
Old May 22, 2023 | 03:11 PM
2013FSport's Avatar
2013FSport
Bolts are reusable.
High temp antiseize compound might be okay if there are no solids in it. Grease absolutely fly or drip out when hot. Use sparingly and for the rear, you can count on it getting on the e-brake shoes. I might do the flange but not the flat area.
Old May 23, 2023 | 05:57 AM
nitroracer's Avatar
nitroracer
Bolts are reusable.
So both front and rear, all caliper carrier bolts are resuable?
Also, I lazily used the word "grease" when I meant copper anti-sieze. My bad! So anti-size behind the rotor hat or no?
EJ255t
Suspension and Brakes
Jul 10, 2019 06:34 PM
luiss11
12
Jun 25, 2013 01:54 PM
pez13oigt
May 15, 2010 08:19 AM
tim817
Feb 8, 2009 08:10 PM
josephdoc
81
Dec 3, 2008 02:26 PM
