IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Ford model a 2jzge
Old Jan 18, 2021 | 08:52 AM
workinonit's Avatar
workinonit
Default Ford model a 2jzge
Hello everybody. I have a project car I need some advice on. I’ve got a 1930 ford model a. I used the engine and auto trans from my 2001 is300 donor car. I’m planning on using the stock cluster. I’m keeping n/a. Does anyone offer a standalone harness for this setup. All the harness I find seem to be geared towards turbo car or older generation engines. Been looking high and low. Or would I be better off stripping down the stick harness. I don’t mind spending good money on a harness that will simplify the install and same me some time. I would appreciate any insight. Thanks!
Old Jan 18, 2021 | 08:58 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Depends If you want to control a factory automatic or not.
Old Jan 18, 2021 | 08:59 AM
workinonit's Avatar
workinonit
I’m sticking with the factory auto so I will need that to be part of it.
Old Jan 18, 2021 | 01:18 PM
1997Soarer's Avatar
1997Soarer
I think you are better off just stripping your stock harness and tweaking things as you go. I do not think any company could build you a custom harness unless you brought the motor and chassis to them.
Old Jan 19, 2021 | 09:43 AM
2001SolarY's Avatar
2001SolarY
There is only one company I have seen that can control the A650e also. There pro system said it would do it. But I will need to try to remember the name. I remember they were in the UK. It is Expensive and then you will need to find support for it where you are.
2008M3
Jan 21, 2021 11:25 AM
SSmith
Jan 14, 2015 09:38 AM
99SC42
SC400 / 300 Classifieds
13
Feb 6, 2010 05:18 PM
